20 Most Recent LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Questions & Answers
2answers
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
2/12/2018 5:09:39 PM • LG 24 in. LDS... • Answered on Feb 12, 2018
I am getting a thermistor error code on our LG
go to google and find list ower trouble shuting and ask about code list
9/11/2017 11:03:22 AM • LG 24 in. LDS... • Answered on Sep 11, 2017
2answers
Ho do I switch the child lock off?
Hello & Welcome to FixYa
To unlock the child lock in your LG Dishwasher, with the door open press the SPRAY & RINSE buttons simultaneously for 15 seconds. Please get back to me if you have any other questions.
Kevin
2/25/2017 4:47:31 PM • LG 24 in. LDS... • Answered on Feb 25, 2017
2answers
How do I rid our lg dishwasher of foul odors?
if every thing else is working good, try first to clean the screen in the bottom and run a cleaning agent through it with nothing in it.you can find the cleaning agent with the dish washer/laundry soap area in your store (same one used on front loading washers)or run 1 cup of white vinager through it
5/8/2015 8:07:33 PM • LG 24 in. LDS... • Answered on May 08, 2015
1E code display. Checked water pressure, changed inlet valve and float. Still 1E code
You need to check the voltage on the inlet valve coil terminals to see whether the main control board is actually switching the valve on to take in water. If not replace the main control board PCB as this is the only other problem remaining.
3/29/2015 9:23:00 AM • LG 24 in. LDS... • Answered on Mar 29, 2015
LG Dishwasher LDS5811ST does not drain last rinse out. LE code displayed. Did the shutoff of power. Most say PCB assembly, some asy control board - ?
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
2/24/2015 6:31:18 AM • LG 24 in. LDS... • Answered on Feb 24, 2015
Lg dishwasher no heat
http://www.repairclinic.com/PartDetail/b200p9/LG-Dishwasher-Heating-Element/5301DD1001G/1582252?modelNumber=LDS5811ST#repairHelpVideoTabs
10/12/2014 4:15:53 AM • LG 24 in. LDS... • Answered on Oct 12, 2014
0answers
0answers
7answers
LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
2/18/2013 10:57:03 PM • LG 24 in. LDS... • Answered on Feb 18, 2013
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
181 questions posted
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
LG Dishwashers
  • LG Dishwashers
Most Popular Question
lg dishwasher lds5811st not drain last
  • Dishwashers
