20 Most Recent Hotpoint 24 in. DWF32P Free-standing Dishwasher Questions & Answers
0answers
0answers
2answers
Dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
10/8/2012 11:41:35 AM • Hotpoint 24 in.... • Answered on Oct 08, 2012
Hotpoint dwf31 dishwasher not emptying
Hello, crash I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>> http://home.howstuffworks.com/dishwasher.htm Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike http://beta.fixya.com/users/mc1bean
10/27/2011 11:06:03 PM • Hotpoint 24 in.... • Answered on Oct 27, 2011
How to remove spray arm
I have a similar machine, so if you are trying to remove the upper spray arm, that one is bolted in, if you wish to remove the lower one, you simply pull up as you turn the arm to the left, (counter clockwise). It will remove, then simply replace by placing it back in place and rotate to the right, (clockwise)
Hope this answers your query, Please rate and comment, Thank You Joe
9/6/2011 3:05:25 AM • Hotpoint 24 in.... • Answered on Sep 06, 2011
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
7/21/2011 5:42:06 PM • Hotpoint 24 in.... • Answered on Jul 21, 2011
We have a Hotpoint DWF31 dishwasher which seems to
Hi
Thanks for using FixYa. Switch off the dishwasher from the power socket and mains and replace all the cables and switch it on after five minutes. You can also reset the breaker. If still the issue is not resolved then press and hold the "On/Off" button and release the button after ten seconds. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
9/20/2010 5:07:06 PM • Hotpoint 24 in.... • Answered on Sep 20, 2010
2answers
My hotpoint aquarius dwf30 will not drain so will not wash...
Do you hear the motor run or is there deadly silence when you select drain.
Does the wash cycle start - do you hear water getting in and washer arms move?
Are there any lights flashing?
8/20/2010 6:53:15 PM • Hotpoint 24 in.... • Answered on Aug 20, 2010
The water went off and the dishwasher was on. Now
sounds like you need a pro with this, turn off until you get help Best Wishes........Helen
4/17/2010 11:33:40 PM • Hotpoint 24 in.... • Answered on Apr 17, 2010
Hotpoint aquarius dwf33 does not always work?!!
I Had this problem its to do with dry joints on the circuit board, solution, resolder all suspect bad joints even though they might look alright especially all those that have heavy electronics connected to the board that could get vibrated.
Peter B
2/27/2010 8:27:01 PM • Hotpoint 24 in.... • Answered on Feb 27, 2010
Dishwasher fills with water but when it should
Hiya,
without the make and model number its hard to tell exactly what the fault is,
Generally this is caused by a siezed motor, could be something got into the impellar or worn out.
When you say trips out, do you mean electrics trip?
If so, you have probably had a leak in the base of the appliance and shorted the motor.
Hope this helps.
Regards
Sussex engineer...
Please rate my help.
10/23/2009 6:21:52 PM • Hotpoint 24 in.... • Answered on Oct 23, 2009
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
72 questions posted
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Dishwashers
Most Popular Question
hotpoint aquarius dishwasher dwf31
  • Dishwashers
