Check the water water supply at the water inlet valve. Remove the supply hoses and check that the small screens in the inlet valve are not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Testimonial: "It's been 5 days and so far so good! Thank you so much for your help. I almost bought a control panel. You saved me 125.00! I appreciate it."
