20 Most Recent
Dewalt Pressure Washer. 4200 PSI 4.0 GPM Pro Triplex Pump Gas Questions & Answers
How ofte I have tochange the water pump oil
every time it gets corrupted with water , it will turn from golden/clear to gold/milky when its time to replace it
an allways ck your oil level in pump and engine an refill if needed when adding gas to tank , its natural to be missing some each time as equipment gets older an older
I have a dewalt 4200 pressure washer that will run for a few minutes and then randomly jus shut off..
Check the bottom of the gas tank for dirt/debris and the float bowl for the same, if it has a fuel filter check that also. Sometimes, if there is debris in any of these places it will settle down when the gas flow is stopped. Then, depending on how the machine is being used or moved around while it is running, the debris will slowly be pulled into the gas flow until it creats a blockage and starves the motor of fuel. When the motor dies the debris settles back down in the tank/float bowl and the motor will start again. Clean out anything in the tank and float bowl and replace the fuel filter if it has one.
Identifying a part on the pressure washer
That would be your unloader valve used for gun control. Allows system to go into bypass mode while the gun trigger is not depressed. This is already preset by factory specs usually a good idea not to move it unless you have a gauge to recalibrate it.
