SOURCE: Belt broken on AP13 planer thicknesser.
Here is a site:
http://www.localaccess.com/1942/ryobi/ap12.html
Find the AP13 belt there... wow...$30... ouch!
SOURCE: replacement on/off switch for Ryobi AP13 318 mm
You can get parts and diagram here.
http://www.ereplacementparts.com/ryobi-ap1301-surface-planer-parts-c-7931_7939_7941.html
SOURCE: Good Day I have got a
Part # 827794 Chain
They sure do look like bicycle chains, but without measuring the links with a micrometer and comparing them with a bicycle chain, i wouldn't be comfortable installing one you made based off of eyeballing it alone. You may know this already, but be sure to remove both sprockets the certain chain rides on, and assembling the 3 pieces as one assembly back on the shafts, its much easier then loosening the shafts from the main unit.
Locate the guide bar retaining nuts on the side of the motor that holds the bar. Use the guide bar retaining nut wrench to loosen the two bolts mounting the bar to the motor.
Locate the chain tensioning screw on the front of the motor housing near the guide bar. Turn the screw clockwise to increase tension and counterclockwise to release tension. Tighten the chain until the chain moves freely along the length of the guide bar, but is tight on the curves of the bar
