SOURCE: Paper Mismatch
The problem is the "spot sensor" that resides on the side of the carriage assembly. It shoots out a ray of light on to the paper when the paper is fed into the printer for printing. It tells the machine..."Hey...there's paper there, start printing". If this sensor is not working properly you will get the error that you are receiving. Most of the time the light still comes on but the sensor board cannot process. You will need to replace the spot sensor of which we have many of....There is a thin plastic piece on the right side of the carriage that covers this sensor. It removes easily so you can see what i'm talking about. Its very easy to replace as well.
Inkworks
SOURCE: Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
SOURCE: won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
SOURCE: Brother DCP 185C cannot print to a glossy paper
in brother printer there. we can choose many types paper. we are pinting now photo in same. choose paper option while giving print command
