20 Most Recent
Panasonic KX-FPG376 Plain Paper Thermal transfer Fax Questions & Answers
Cannot go back to default greeting message
According to the Operating Instructions for this machine, chapter 7.1.1. says that by erasing your recorded message, the machine should be set to play the pre-recorded greeting message again. And I guess you can then go on and try to record a new message, hopefully it will be more successful this time. I don't have this machine myself, but I wish you good luck!
10/19/2011 5:18:07 PM •
Panasonic...
Answered
on Oct 19, 2011
Number of rings
Press MENU, then enter #06, then press the number of rings before the fax picks up by pressing 1,2,3, or 4 (4 being the maximum number of rings)
Press SET, then press MENU again to exit. Best of luck!
Greg
5/22/2009 2:24:55 PM •
Panasonic...
Answered
on May 22, 2009
Recording a greeting
You need to be in Tam fax mode firstly.
1, {#} {0} {0} {1}:= “TAM/FAX” (default)
2, Press {RECORD} repeatedly to display “TAM GREETING”.
3, Press {SET}. A long beep will sound.
4 Speak clearly about 20 cm ( 8 inches ) away from the microphone.
The display will show the remaining
recording time.
5 When finished recording, press {STOP}.
The unit will repeat your message.
To erase and start again
Tam/fax mode again.
2 Press {ERASE} repeatedly to display “TAM GREETING”.
3 Press {SET}.
To cancel erasing, press {STOP}.
4 Press {SET}.
should be good now.
Regards
Richard.
4/24/2009 8:37:24 PM •
Panasonic...
Answered
on Apr 24, 2009
People on other end of connection cannot hear me, although I can
Check the volume...
Ringer volume
3 levels (high/low/off) are available.
Make sure the handset is idle.
1 Press {FUNCTION}.
2 Scroll to “Ringer volume” by pressing {down} or {up} repeatedly, and press {right arrow}.
3 Press {down} or {up} repeatedly to select the desired volume.
4 Press {right arrow}.
This is the handset volume
To turn the ringer OFF:
Press {down} repeatedly until “Ringer off” is displayed in step 3.
Regards
Richard.
4/24/2009 4:53:45 PM •
Panasonic...
Answered
on Apr 24, 2009
The mic in my handset
There are many possbilities for this .check if there is a mute button on display.may bi it is pressed if not check handset cable by replacing it .check mic or replace it .and check connectivity of supply to mic.MIAN AKHLAQ
1/3/2009 2:18:26 PM •
Panasonic...
Answered
on Jan 03, 2009
Mic not working?
just check if there is a button nmed as mute it is still pressed just check it .if not just open receiver and check mic s soldering .if ok just change mic with new one.by mian jee
12/18/2008 1:53:35 AM •
Panasonic...
Answered
on Dec 18, 2008
Volume control
Is there a sliding switch on the handset or on the left side of the machine?
11/22/2008 9:59:46 PM •
Panasonic...
Answered
on Nov 22, 2008
