It happens about 50% when the printer is first turned on, but once warm, pretty much 100%. I don't see any obvious issues with the rollers, removed all the paper bits that were left over from previous jams, but still continues to happen.
SOURCE: Manual Feed Gets Jammed
There could be an obstruction in the paper path or the roller might need to be clean or replaced.
SOURCE: hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
[email protected]
hope fore replay.... :)
