20 Most Recent Xerox Phaser 8860MFP Printer Questions & Answers
That error signifies that the printhead reservoir is overheating and the printhead needs to be replaced. The part number is 017K04540 and can be purchased at www.iteminconline.com.
Xerox Phaser... | Answered on Mar 18, 2016
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Xerox Phaser... | Answered on Jan 29, 2015
if the control panel display is completely blank but the printer works, you have a faulty panel. I can order it, feel free to contact me, its possible xerox will still cover this under warranty. Call xerox tech support, tell them the issue and see if the control panel would still be covered under warranty eventhough your machine is out of warranty. instructions come with replacing the part.
Xerox Phaser... | Answered on Dec 20, 2014
The code means that the head tile restraint spring is not in place.
This is what engineers check for before replacing any parts:
• Check that the Process Drive gear train is properly homed.
• Check for obstructions or ink spills around the Printhead. Spilled ink could indicate the
system was tipped while hot. Check for blockage in the Purge Tube.
• Verify the Printhead travels smoothly from left to right.
• Check the Printhead Restraint Arms.
Xerox Phaser... | Answered on May 26, 2014
That error indicates the Drum Temperature Sensor circuit is shorted out. I you have access to the service diagnostics, run the Drum Temperature Sensor test. If it fails, replace the drum temp sensor. If that doesn't solve the problem, replace the sensor wire harness.
130K75210, Drum Temperature Sensor
Xerox Phaser... | Answered on Mar 16, 2014
If the machine is able to make copies, print or receive faxes, then the display is most likely defective and needs replaced.
Please go to start menu, then to DEVICES AND PRINTERS. Open, click correct application printer, click that open. Go to customize. There is where you choose the style of printing. Make sure you click APPLY when finished. It should fix it for you right away.
Xerox Phaser... | Answered on Mar 06, 2014
It is on the side. I'm not sure which side, but the side that all the cords plug in.
Xerox Phaser... | Answered on Nov 13, 2013
Take out the paper! just kidding :)
I guess it's a problem with a sensor in the output tray that has either fallen off or got stuck in an up position by some paper.
Either you put it back, remove the paper that is stopping the sensor from moving freely or call an engineer
Xerox Phaser... | Answered on Nov 10, 2013
Apparently the machine is telling you to remove the copies made from the output tray, probably it is getting heavy.
Xerox Phaser 8860MFP Printer Logo
55 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
find service manual xerox
  • Office Equipment & Supplies
