Hi Anthony, it is very likely that the pedal cable is defective (short circuit or open) and when plugged in, the keyboard interprets that it is pressed and then generates the fault
Check the pedal and comment
Greetings Franco Dosil
Hola Anthony, es muy probable que el cable del pedal se encuentre defectuoso (cortocircuito o abierto) y al enchufarlo, el teclado interpreta que esta presionado y entonces genera la falla
Revisa el pedal y comenta
Saludos Franco Dosil
My initial thought would be as there is no sound that you have plugged the cable into the wrong socket. Please double check carefully and report back.
