20 Most Recent Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability Questions & Answers
Try uninstalling and reinstalling both the keyboard and the game. If that doesn't work then the keyboard may not be compatible with the software.
Casio Ctk 496... | Answered on Dec 05, 2016
You don't really expect anyone to diagnose a problem and suggest a solution based on that, do you?
Casio Ctk 496... | Answered on May 18, 2016
Hi, Assuming you have tested with another adaptor then invariably it is a broken solder joint on the power input connector.
Re soldering will work but eventually the same thing occurs.
Set the connector in epoxy resin (Araldite) or better still mount a new connector in the case and wire with flying leads.
All the best, Chris the Fader.
Casio Ctk 496... | Answered on Sep 21, 2014
Hi, There are two contacts for each key. one makes contact before the other, the time between the two determines the time the key takes to be depressed, hence the touch.
Usually the contacts need cleaning, but in this case as itis 8 notes it may be the common keyboard scanning matrix. The matrix is 8 x ..up to whatever so check the line/column connection, or the associated diode.
Usually this is an easy fix, just time consuming taking the instrument to bits.
Good Luck, Chris the Fader
Hi! When I turn on my keyboard it shows "03.2" on the multifunction display and the lights of "Split", "Digital effect" and "Touch response" remain "ON" and in someway it get blocked for the most of the functions. I cannot turn off that lights. Please, help me!!! You can answer me to dramosm@hotmail.com Thank you very much
Casio Ctk 496... | Answered on Sep 14, 2014
http://support.casio.com/en/manual/manual.php?cid=008
Casio Ctk 496... | Answered on Jul 13, 2014
CASIO LK125 does not have any MIDI interface so I do not understand what software you are after.
manual available at:-
http://support.casio.com/manualfile.php?rgn=4&cid=008006139
i'm problem disc no support from rolland type...why.??
Casio Ctk 496... | Answered on Mar 12, 2013
There probably is NOT a fuse and usual cause is problem with the adapter or the power connectors. Broken solder of the connector in the keyboard is common. Broken cords on the adapter is common as well.
Casio Ctk 496... | Answered on Jan 14, 2013
When wiring around circuit board cracks, one must use adequate sized wires and keep the leads short. Also you MAY have a microscopic crack in yet another conductor that flexes when you play the keyboard and freezes it. Use a high intensity LED light from the topside to "candle" the board and look for cracks. Look for cracking of the board material that may have tiny cracks in the circuit traces.
Casio Ctk 496... | Answered on Jan 15, 2012
Casio Ctk 496 Electronic Keyboard with 61 Keys and Singalong Capability Logo
Popular Tags
82 questions posted
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
View Most Popular
Casio Music
  • Casio Music
Most Popular Question
connect casio ctk 731 computer
  • Music
