20 Most Recent
Casio WK-210 PACKAGE 76 Keys Electronic Keyboard with 570 High Quality Tones, FREE Stand, FREE Adapter and FREE Microphone Questions & Answers
My qt-6100 stopped communicating with the kitch screen? replaced ethernet cable, what next?
This end of the week, a companion some way or another figured out how to gain my Netflix secret phrase. Normally, I needed to transform it. It took me a while to discover where I could go on the site to change the secret phrase. After around 5 minutes, I at last made sense of it.
From Desktop Browser
Login to Netflix and guarantee the essential record holder's name is chosen in the upper-right corner of the screen. In the event that you have overlooked your secret phrase, go to the Password Reset page and enter the email address for your record, at that point pursue the bearings in your email. Contact on
Netflix Support Number Australia.
·Mouse over your name in the upper-right corner, at that point pick "Your Account".
·Select the "Change secret key" connect.
·Sort your "Present Password", "New Password", at that point "Affirm New Password".
·In the event that you wish to boot any gadgets that utilization Netflix out of your record and want the new secret word be entered next time it is utilize, verify the " Need all gadget to sign in another time with new covert word."
·Select "Spare".
Re: Casio WK-210. Audacity, Jet Audio and Ctrl
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
When I plug in stereo
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
i have a problem with
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
One of my keyboard black keys is playing louder
One of the two contacts of that key is dirty. This cause the key velocity to be read as maximum making it loud. The keyboard contacts are conductive rubber pills that press across circuit traces on a board under the keys. CLean the pills and the traces GENTLY with ONLY 99% isoprophyl alcohol and Q tips. Getting at the contacts requires a lot of careful disassembly of the keyboard to get at the contacts.
I have a Casio electronic
ALBERTA
E
NESA
121-3208-8 th Ave NE
CALGARY , Alberta T2A 7V8
403-252-6988
BRITISH COLUMBIA
B E
Cal-Q-Tronics
#225 - 624 6th Street
NEW WESTMINSTER , BC V3L 3C4
604-524-4926
Fax: 604-524-4928
MANITOBA
B E (No diaries)
NESA
1580 Erin Street
WINNIPEG , Manitoba R3C 2T1
204-783-6185
NEWFOUNDLAND
E
Bristol Business (West Empire Plaza)
391-395 Empire Ave - Unit 6
ST. JOHN 'S , Nfld. A1E 1W6
709-722-6669
ONTARIO
A B C D E F
Casio Service Centre
141 McPherson Street
MARKHAM, Ontario L3R 3L3
905-248-4400
800-661-2274
QUEBEC
A B D C E
Madjitech (Omar)
1202 Bossuet
MONTREAL , Quebec H1N 2R4
514-255-7299
Gary
(Wk-200) Volume wheel spinning all the way around and not stopping at "min" or "max"
If the volume wheel on your Casio WK-200 keyboard is spinning all the way around and not stopping at the "min" or "max" positions, it is likely that the potentiometer that controls the volume has become faulty or damaged. A potentiometer, or pot for short, is a type of variable resistor that is commonly used to control the volume on electronic devices.
Here are a few troubleshooting steps you can try:
- Power off your keyboard and unplug it from the power source.
- Remove any batteries from the battery compartment.
- Locate the volume potentiometer inside the keyboard. It should be near the volume wheel and will have three pins or legs.
- Check the potentiometer for any visible signs of damage, such as cracks or broken pins.
- Gently wiggle the volume wheel while observing the potentiometer. If it appears to be loose or wobbly, it may need to be replaced.
- If you have experience with electronics and soldering, you may be able to replace the potentiometer yourself. Otherwise, it is recommended that you take your keyboard to a qualified service technician for repair.
If the issue persists after attempting these troubleshooting steps, it is likely that the potentiometer needs to be replaced. In any case, it is best to seek the assistance of a professional technician to avoid causing further damage to your keyboard.
4/10/2023 12:24:14 PM •
Casio Music
Answered
on Apr 10, 2023
Casio tone bank m120 no power,ic AN8054 has been blown off any substitute for ic is available please let me know
The AN8054 is an integrated circuit used in the Casio Tone Bank M120 keyboard. If it has been blown off, you will need to replace it. An equivalent replacement for the AN8054 is the LM358N, which is a dual operational amplifier that can be used as a substitute. Other equivalent options you can consider include the LM741, LM7808, and LM324. It's always recommended to check the datasheet of the substitute IC to ensure it meets the specifications and requirements of the original IC.
1/31/2023 6:20:11 PM •
Casio Music
Answered
on Jan 31, 2023
Casio CDP-100 sustain pedal not working
It sounds like you may be experiencing issues with the sustain pedal on your Casio CDP-100 digital piano. The problem may not be with the pedal itself, but with the internal connections or circuitry of the piano.
If you're unable to factory reset the piano and it's not responding to the sustain pedal, it's likely that there is a problem with the main board. This is a complex issue that may require professional repair.
However, before giving up on it, you can try the following steps:
- Check the connections: Make sure that all of the connections between the pedal, the piano, and the power supply are secure and that there is no damage to the cables.
- Check the power supply: Make sure that the power supply is working properly and that the piano is receiving power.
- Try to update the firmware: Check if there is a firmware update available for your piano on the Casio website. Updating the firmware may fix the problem.
- Check the manual: Consult the piano's manual for troubleshooting steps, it may have some information that can help you.
If none of these steps work, it is likely that the problem is with the main board and it will need to be repaired by a professional technician. Unfortunately, this can be an expensive repair. Keep in mind that attempting to repair a digital piano can be dangerous if you're not familiar with the proper procedures and safety precautions.
It's important to keep in mind that the piano was second hand and you were aware of a problem with it and you have been given a lower price as a result. It is also important to note that buying second hand musical instruments may have hidden issues, which is why it's always advisable to inspect it thoroughly before buying it or to buy from a reputable seller who can give you a warranty.
Regenerate response
1/17/2023 11:39:03 PM •
Casio Music
Answered
on Jan 17, 2023
I have a Casio celviano ap-65. It turns on but no sound. Any suggestions?
If your Casio Celviano AP-65 turns on but there is no sound, there could be several possible causes for this issue. Here are a few steps you can try to troubleshoot the problem:
- Check the volume: Make sure that the volume on the piano is turned up and that the volume control on any external speakers or amplifiers is also turned up.
- Check the connections: Make sure that all cables and connections are securely plugged in and that there are no loose or damaged cables.
- Check the power supply: If the piano is plugged into an outlet using an extension cord or surge protector, try plugging it directly into the wall to eliminate any issues with the power supply.
- Check the internal speakers: If the piano has internal speakers, make sure that they are not damaged or malfunctioning.
- Check the settings: Make sure that the piano is set to play through the internal speakers or any connected external speakers or amplifiers.
If these steps do not resolve the problem, it may be necessary to have the piano inspected by a professional. They will be able to diagnose the issue and recommend the appropriate repair.
1/16/2023 6:38:27 AM •
Casio Music
Answered
on Jan 16, 2023
