my laptop used to do the same thing it was overheating so i place 3 vhs cassettes in boxes under the edges of it to allow more air circulation and now it is ok just a thought
The ViviCam T027 does not record sound in video mode. You can add a soundtrack using video-editing software on a computer, but you cannot record one on the camera.
I know that wasn't the answer you wanted to see, but there it is.
You are NOT supposed to re-format using your PC...you re-format just using the device itself...refer to your operating instruction to try to re-format again or download instructions from www.olympusamerica.com
This is an indication that the unloader not working properly. When you release the trigger the unloader senses the increase in pressure and bypasses the water into the water inlet. When the unloader is not working and you release the trigger, the water pressure builds quickly and overcomes the power of the engine shutting it down. Here is the manual for your machine, http://www.pressurewashersdirect.com/manuals/Simpson_WaterBlaster%20manual_2.pdf
and some information about troubleshooting from the manual.
"Not Unloading. Leak in Gunvalve or Hose. Repair gun leak . Replace leaking or broken hoses. Debris or wear in Check Valve. Remove Check Valve parts and clean. Check O-Ring. Reface with emery cloth, or replace checkvalve. Damaged Piston U-Cup. Rebuild Unloader Valve (Service Center)."
Usually when the unloader fails the pressure regulator will most likely need to be replaced as the unloader is usually incorporated within. For now try lowering the pressure some and just tie the trigger open untill you can service. Good luck.
All i can advice is remove the unload from the event. in case, you can
add a timer in your form, in the click event start the timer, and remove
the objects in the Timer event (and remember to stop the Timer)
And while scanning for more solution, i bumped into this site and here's a solution that i think might help you.
There is an Unload statement in the Paint
event for the form or for a control on the form that has the Paint
event.
Remove the Unload statement from the Paint event.
There is an Unload statement in the Change, Click, or
DropDown events of a ComboBox.
Remove the Unload statement from the event.
There
is an Unload statement in the Scroll event of an HScrollBar
or VScrollBar control.
There
is an Unload statement in the Resize event of a Data, Form,
MDIForm, or PictureBox control.
There
is an Unload statement in the Resize event of an MDIForm
that is trying to unload an MDI child form.
There
is an Unload statement in the RePosition event or Validate event
of a Data control.
There
is an Unload statement in the ObjectMove event of an OLE
Container control.
Open my computer, there will be a new drive listed there (ie: f: ) or something like that.. This is your usb driver.. double click on that, and in there, there should be a setup.exe file, double click that to install Arcsoft.
Ok what you can do (with power off and unplugged) is open the unit up, find the load and unload motor on the DVD carriage and manually turn it this will unload the disk.
