SOURCE: Sony KP57WS510 Blinking 8 times
You have a strt up problem. I found, in a similiar Sony Big Screen a couple of fixes. First thing to try is unplug the set from the wall for about 15 minutes and then plug it back in and retry the set. If this corrects the problem, I suggest you purchase a good ( Not a 5 dollar piece of junk) surge protector. ( One rated at 500-1500 joules. A good surge protector may prevent future processor lock ups. If this doesn't correct the problem, the problem lies in the circuit boards of the set. I found one problem in a Sony like you describe had a bad convergence chip and a burned resistor in the same board. Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
SOURCE: error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin?
Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on?
Press START/PAUSE once. The door will unlock.
