20 Most Recent Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Questions & Answers
Hello friend, thank you for your post!
Based off the information you have provided it sounds like it could be a possible issue within the control panel of your Frigidaire washer. I understand that you have replaced your door lock and switch assembly but it could also be an issue with the keypad of your appliance. I would recommend having a professional come out to properly diagnose your appliance to avoid unnecessary part purchases. I hope this is helpful. - Matt
Frigidaire... | Answered on Aug 26, 2014
How about save yourself some cash and put it on spin manually and try that see if that works.
Frigidaire... | Answered on Dec 04, 2013
(no promises but it is worth trying this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor not spinning fast enough. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Frigidaire... | Answered on Jun 27, 2011
is the belt tight? If not the spin cycle will run slower causing you to receive very wet clothes beleive me. Any slower speed they are still soaked.
Frigidaire... | Answered on Jun 05, 2011
the flashing is an error code, count the number of blinks. also turn the power off. wake up the washer by touching any one bottom. then press cancel an pause buttoms at same time. it will display an error code. write that down an repost it
Frigidaire... | Answered on Jun 04, 2011
  • Inspect externally visible components - Somewhere adjacent to your machine will be two faucets, one for cold and one for hot water. Flexible hoses with standard garden hose type fittings on each end connect these faucets to the water inlet valves for your machine. Check to see if either the hot or the cold water hose is leaking either along its length or where it attaches to the faucet or to the water inlet valve. In the simplest case, you may simply need to tighten the hose slightly at one end or the other. A pair of pliers can be used to tighten the hose fitting, but be very careful not to over tighten at the water inlet valve end because here the hoses screw onto plastic or nylon threads that can be stripped by over tightening. The hose fittings contain rubber washers or washer filter screen combinations that can be replaced if they have deteriorated. These can be obtained from local home improvement stores or appliance parts suppliers. If the hose itself is leaking then buy replacements for both the hot and cold water hose since they have probably experienced similar deterioration. Another possible source of water on the floor is an overflowing drainpipe. The drain hose from the washer normally has a curved end that hangs loosely on a vertical drainpipe (sometimes on a laundry sink) that connects into your sewer system. If the drainpipe or its connection to the sewer system is partially stopped up you will get an overflow when the washer empties. On a front loading-machine check for leakage around the door or any obvious deterioration in the gasket material. Get a helper and use a heavy piece of cardboard or masonite to protect finished floors if you have to slide the machine out for access. If the leak is not external you will have to look inside the machine.
  • 2 Common washing machine components/operation - Understanding what you are looking at inside the machine requires some background about how washing machines operate. The washing machine has a water inlet valve assembly to turn on and off the hot and cold water that must flow into the machine. There are also flexible hoses to connect to your homes hot and cold water supply plus a rubber drain hose for emptying water from the machine. The machine has a tub for holding the water during washing and rinsing and the tub contains a "basket" (the part with holes in it that you see on looking into the machine) for holding the clothes. It has an agitator to accomplish the washing operation. It has a pump to move water from the tub to the drain and some kind of spin mechanism to remove additional water from the clothes after the tub is emptied. There is also an electric motor to power the agitator, the spin mechanism, and the pump as well as a transmission to couple the motor to the agitator and spin mechanisms. There may be a filter to remove lint during the wash cycle. Finally there is a control panel to select specific cycles, temperatures, agitation speed, amount of water in tub (load size), washing time etc. Inside the machine there are also hoses to connect the water inlet to the tub, to connect tub to pump to drain hose, and to interconnect the tub and pump and filter (if present), etc. The most likely points of water leakage are the internal and external hoses and their attachment points, the water input valve assembly, the pump, and the water filter. A less likely leak would be from the tub itself rusting out on an old machine or from some kind of mechanical failure or chronic imbalance that caused the basket to rub the tub during spin. The link "Online Appliance Repair Manuals" under resources below provides more detail, diagrams, and description for some specific brands as well as good general information. If you have not worked on washing machines before, it would be very helpful to read the first two short chapters in this reference or to read some equivalent tutorial material covering basic repair techniques and principles of operation and containing lots of explanatory figures.
  • 3 Looking inside the machine - Here you will probably need a manual or at least the online resource cited just to get access to the inside. The assembly/attachment techniques are not always obvious just looking at the outside of the machine. Older machines sometimes had access panels on the back that provided a place to look in, but newer machines may require removing the cabinet and this is much easier if you know the recommended approach. Be very conscious of safety while working inside the cabinet. There are electrical shock hazards from exposed connections and mechanical hazards from moving parts plus possible wet wiring from water leaks. Keep machine unplugged and water turned off except as needed for tests. Also turn off water while moving machine for access and have a bucket to put the drain hose in. Inspect the inlet control valve and the tube connecting the valve to the washing machine tub. Check all internal hoses and their connections for leaks. Inspect bottom and sides of tub for any problems. Inspect the body of the water inlet valve assembly, the pump and the filter for signs of leaking through cracks or bad gaskets. Check all of the areas for wetness or signs of mineral deposits where leaking has been occurring. Remove failed parts referring to manuals or online sources as needed. Most hose clamps can be removed with ordinary slip jaw pliers. Some hose clamps may be of the screw type. If a hose is stuck and difficult to get off after the clamp is moved back out of the way, grasp the area where the hose overlaps the pipe with channel lock pliers and try to rotate it slightly back and forth to break the bond. Some sheet metal or machine screws may need to be removed to dismount parts.
  • 4 Obtain new parts - You will need to know the make, model and serial number for your machine. If you have an owner's ,manual it will tell you where to find the "nameplate" which has this information. Lacking a manual try looking on the back of the machine or possibly just inside the door or sometimes down by the base. If you have an owner's manual it may also have a parts diagram and parts numbers. Your options for obtaining parts include getting from your dealer (e.g., Sears parts), finding a local appliance parts supplier (check your yellow pages and call first about availability), or ordering from an online appliance parts supplier. Ordering online is probably the cheapest, but if you are inexperienced it is nice to walk up to a counter with the old part in hand (along with your machine information) and get personal assistance in obtaining the right replacement.
  • 5 Install parts - After installation check carefully to be sure the leak is repaired. Reassemble the machine.
  • Read more: How to Find a Leak in a Washing Machine ' eHow.com http://www.ehow.com/how_2285965_leak-washing-machine.html#ixzz1D5Uk4sk2
    Frigidaire... | Answered on Feb 05, 2011
    Welcome to FixYa.
    Based on what you've described, and provided the unit is draining ( and I mean the drum is clear of water aside from the items being soaking wet )...you likely need a door lock/switch assembly.
    **The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, ASIDE FROM PUMPS BEING OBSTRUCTED.**
    I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
    You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
    As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
    1) **UNPLUG THE WASHER FROM THE WALL OR TURN OFF THE BREAKER...SAFETY FIRST.**
    2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
    3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
    4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
    Let me know if you need further assistance going forward or if my instructions are not clear.
    P.S.
    There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
    Thank you for visiting FixYa today. Good luck.
    Regards,
    Macmarkus :)
    Frigidaire... | Answered on Jan 15, 2011
    Check in the pump that nothing is obstructing it . If nothing and the pump is still not turning then it must be replaced.
    Frigidaire... | Answered on Nov 20, 2010
    remove and install a new bellows kit for a Fridgidaire front-loading washer model ftf2140es0
    Frigidaire... | Answered on Jul 05, 2010
    Sorry, this isn't a solution. We are having the same problem, did you ever find a solution?? Our machine actually won't run a wash cycle anymore, just keeps beeping at us like it is possessed!
    Frigidaire... | Answered on Jun 27, 2010
    Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
    Frigidaire... | Answered on Jan 26, 2010
    Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
    49 questions posted
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    J. Bradshaw
    Archie Ferrarini
    Archie Ferrarini
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
    View Most Popular
    • Frigidaire Washing Machines
    Most Popular Question
    machine leaking out
    • Washing Machines
