SOURCE: canon pixma ip90 green light
Hi there SWCopiers,
Four flashes indicates 'Ink tanks installed incorrectly' or 'Printer needs repair'.
Click here for iP90 ink tank install procedure.
Click here for reset procedure.
Click here for instruction on contacting Canon Support. They have been very helpful. If it turns out that one of your ink tanks is faulty, they have replaced them at no cost in the past.
Hope this helps.
Remember: Good things come to those who Rate!!
Mike
SOURCE: flashing 4 orange lights
The power light flashing orange four times consecutively means that one, or both, of the inktanks is/are installed incorrectly. Follow the steps below to resolve the issue.
I hope this helped
SOURCE: why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
SOURCE: Canon i860 orange light flashes 5 times. What
This link will take you to a list of possibilities listed at Canon's website.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9387
SOURCE: My canon ip90 printer cartridges is stuck to the
LED blinking in Orange color 5 times = Print head is not installed properly or the print head has reached to the end of life.
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
