Krishna Kant Posted on Apr 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xerox 5790 optional tool kit No. - Xerox Office Equipment & Supplies
JMJr
Level 3:
Master:
  • Xerox Master 694 Answers
  • Posted on Jul 14, 2020
 JMJr
Xerox Master
Level 3:
Master:
Answers
694
Questions
0
Helped
166691
Points
2276
How to solve power supply fault xerox workcenter 5790
Must check the error code first. Switch the machine OFF, took off the power cable outside. Let the machine pause 15 minutes.If it has a little "Reset"button backside push 2-3 times on it. After that connect the power cable and switch the machine ON. If this does not help must check or change the power supply.
Xerox 5790 power supply fault
What is the error code displayed on screen ?
2answers
How to solve Power Supply Fault in Xerox 5790
This fault is coming on my copier 5755 what is the solution
5790. How do I correct problem 09-560?
09-560
HVPS
High Voltage Power Supply I think.
5790. How do I correct 09-560 fault?
That is a high voltage power supply error, start by cleaning the charge scorotron and corona wires and cleaning contacts. If error persists, replace the HVPS.
2answers
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
2helpful
Out of fuser web.I need to reset it on nwm.How I can do it ? Please help Mashine is xerox 5790
1.start +0
2.6789
3.dc135 hsfi line 20 clear
4.nwm accsess
6.read write
7.reset 3984 to 0,
8.reset 3985 to 0,
9.reset 3986 to 0,
10.reset 3987 to 0
Then open mashine door,take out fuser web sensor and put it back.
Message out of fuser is gone.Now it is ready to make copies.
Xerox Regal 5790 Paper Jam
Wat is the code about this problem 08-300 its maine the Füser is not start on the same time when the cluts is not werking oder the pall is not gooing to this point open the front dore an you cann sche small cluts this is no good contact of its not working then you can puss the small wiel to the bik rol en the paper wil to the füser turn the green wiel and the paper go to füser out. I had this problem also with Xerox 5760 the same .
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
