Question edited for FULL 'make model (what it is)'.
Question moved from Computers to correct category.
"DATA ERROR CANCELING..."
Output was stopped because a problem was found in the data received.
Operation cannot be continued. Check whether or not there is an error in the data. Check for a problem with the connector cable or the computer, and redo the operation from setting up the object to be printed on.Roland Technical Support.
ERROR 2:
Appears if the number of parameters differs from the permissible number.
You can download the EasyCut Pro software from https://www.easycutpro.com/ and give it a try.
This vinyl cutting software works great with Roland GX-300 CAMM-1 Pro Vinyl Cutter.
What software do you use? The software I'm using is Easy Cut Studio., you can download the trial version from https://www.easycutstudio.com/ .
From the cutter menu, choose manage cutters and add "Roland CX" option.
If you are having issues cutting, make sure you have the latest USB driver installed.
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
