SOURCE: vitantonio waffle maker
It sounds as if the iron isn't cooking at a high enough temperature. I'd try turning the iron to the highest setting, first (the thermostat may not be giving a correct reading, keeping the temp too low), before considering getting a new iron. The good news, though, is that a new waffle will only set you back about $20
Hope that helps
Please rate accordingly
Thank you
Computerrep
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it. My wife decided instead to disassemble it. The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads. It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't. Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
SOURCE: Smoking Fan Assisted Oven
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
SOURCE: Black smoke on acceleration diesel x-type jaguar
can anyone tell me where the intercooler is on a 05 plate jaguar x type 2.0 diesel thanks
SOURCE: Turns on but doesn't Cook
It sounds like this is a common poblem but I found what it is. I am a mechanical engineer and fix anything and everything. I had the same thing with my Villeware model 2010. I took it apart and traced with a meter to find the problem. I found the wires to the heating elements in the bottom half melted and shorted where they cross (bad design) just past an inline fuse ( good part of the design!). I can't find any place that carries parts and contacted Villaware direct but do not expect any luck in getting a new wire harness. The fix is either the proper harness or the correct fuse and high temp wire and correct crip connectors. Bypassing the fuse or using incorrect wire would be dangerous, would destroy the control board if another short would occur or possibly lethal from shock or fire.
