20 Most Recent Wells F-101(21186) Deep Fryer Questions & Answers
Hi there.
You may need to calibrate the new thermostat and in doing so, you will need a calibrated thermometer with sensor dipped in oil at about one (1) inch above the fryer thermostat sensing bulb.
Record the cut-off temp (when indicator light goes off) and compare it with the thermostat setting.
The thermostat has a calibration screw ( - ) recessed in the middle of the shaft, you will see the when you pull off the thermostat knob. this calibration screw can be turned by a precision screw driver, turn clockwise to decrease the cut-off temperature ; turn counterclockwise to increase the cut-off temperature.
Just make sure that the unit is preheated or have cycled at least 5 to 8 times and the oil is new before performing the calibration.
Regards.
Wells... | Answered on Nov 13, 2014
You can gain access and be able to remove the power switch by lifting first the fry pot.
Wells... | Answered on Jun 18, 2011
It is not economical nor even possible to convert electric fryer to gas fryer since the tank construction and parts are very different.
Wells Kitchen... | Answered on May 20, 2015
Wells Fryer manuals can be downloaded free at www.wells-bloomfield.com
Any competent service technician could cobble something like this together, but I'd challenge the insurance company, as this fryer is UL approved. Such a modification would be expensive and void the warranty and NSF and UL approveals.
Wells Kitchen... | Answered on Sep 23, 2014
Hi there! If hi limit wont reset when button is pushed, there might be a mechanical problem inside the part which prevents t from resetting, you have to replace the part.
Visit www.middleby.com and select wells to find the nearest authorized parts dealer near your area.
Regards.
Wells Kitchen... | Answered on Jan 28, 2013
check your program for the basket lift, also check the mechanisms.
Wells Kitchen... | Answered on Mar 31, 2011
Running the fryer with no oil will over heat the coil very quickly...this caused the element to burn out...
That element will be replaceable...
If you call these guys you should be able to purchase a new element from them...
http://www.fryerworld.com/wells-f49.html
heatman101
Wells Kitchen... | Answered on Nov 23, 2010
By purchasing a natural to propane conversion kit & it also might require the burner orfices to be changed out too. By contacting Wells@ 888-492-2782 with your model & serial # in front of you, they will be able to give you the part #s needed. If they will not sell you the parts then you can probably purchase them from Stove Parts Supply in Ft. Worth Texas
Wells Kitchen... | Answered on Jul 25, 2009
Wells F-101(21186) Deep Fryer Logo
3 questions posted
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
Joseph Hoffmann
ray gallant
ray gallant
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Wells Kitchen Appliances - Others
Most Popular Question
fryer heats up but
  • Kitchen Appliances - Others
