20 Most Recent
Wells F-49 21148 Deep Fryer Questions & Answers
Unit overheats. Replaced thermostat
Hi there.
If overheating trips the hi limit and as you said, the thermostat is new, the first thing to consider is the wiring connection or is it properly wired?
You can download Owner's Manual for your fryer containing wiring diagram which you can use as reference at http://www.wellsbloomfield.com/wellsmanuals.aspx/
Regards.
Fryer isn't turning on. tried reseting. still no luck
Hello. Here is a wiring diagram for your unit:
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307298.pdf
Check to see that the thermostat clicks at or about just above on, try again the reset, sometimes it is hard to push in all the way. If that does not correct the problem, make sure your power is on, do any indicators light? It could be as simple as a burnt of wire, you will need to check the resistance of the parts to tell any more, thermostat, and hi-limit should read closed (zero). The element should read 4 to 15 ohms each, there are 3 in the tube. The relay coil should be anywhere from 200 to 1200 ohms, the contacts open. I have seen broken wires in the pivot elbow where power comes up the the element head.
Hope that helped, and thank you.
If you need more help, "ask me"
Wells f 49 fryer
Yes it should have resistance through it unless it has been opened by a rise in temperature. Tell me what your problem is I can probably help you out.
Thanks
