20 Most Recent
Wells F-686 Deep Fryer Questions & Answers
Wells deep fryer won't heat
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
Wells 35lbs fryer double vat
Hello
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Thanks
Wells electric fryer model f-67 wont reset
Hi there! If hi limit wont reset when button is pushed, there might be a mechanical problem inside the part which prevents t from resetting, you have to replace the part.Visit www.middleby.com and select wells to find the nearest authorized parts dealer near your area.Regards.
Hi I believe I have
Running the fryer with no oil will over heat the coil very quickly...this caused the element to burn out...
That element will be replaceable...
If you call these guys you should be able to purchase a new element from them...
http://www.fryerworld.com/wells-f49.html
heatman101
Model FGS-40 Ser Fe 1959 How do I change it from
By purchasing a natural to propane conversion kit & it also might require the burner orfices to be changed out too. By contacting Wells@ 888-492-2782 with your model & serial # in front of you, they will be able to give you the part #s needed. If they will not sell you the parts then you can probably purchase them from Stove Parts Supply in Ft. Worth Texas
