SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
SOURCE: Dyson Animal 17 - brush stopped turning
The belt will stop itself from spinning if you accidentally picked up a shoestring or vacuumed the edged of a carpet and the carpet got caught. To have the brush spinning again, simply step on the front of the machine, pull back the handle, turn the machine on with the red power button and press the gray button next to the red button - that's the ON/OFF button for the brushbar. If it doesn't spin, press and hold the button down for 10 seconds. If it still doesn't work, call the Dyson helpline, they'll have you open up the cleaner and inspect the belt and brushbar motor and if all else fails, they'll refer you to a local repair dealer in your area to fix it.
SOURCE: Dc 31 animal: even when
Sorry to hear you're having difficulties with your DC31 Animal. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone with you to identify the cause of the issue. They'll be happy to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Hi Jennifer,
I'm sorry to hear you're having difficulties with your DC32 Animal. If you've been unable to resolve this issue after checking for blockages and washing the filter, I'd encourage you to give the Dyson Spain Helpline a call on 902305530. Alternatively, if you email [email protected], someone will be in touch as soon as possible to provide assistance.
Best wishes,
Jack
http://www.dyson.com
SOURCE: DYSON DC16 STOPS & STARTS
go to http://content.dyson.com/support/
and see the complete information for troubleshooting, manual, videosetc.and fix it.
God bless you
