20 Most Recent
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Questions & Answers
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
The canister will not snap
Sorry to hear you're having difficulties with your DC14. If the canister won't reattach to the vacuum, you might want to check you have it assembled correctly - you can find out how to do this in the user guide supplied with your cleaner. In case you don't have this to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdfIf you're certain the bin is assembled correctly and it still won't attach to the cleaner, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Vacuum gives off a strange smell (stink) and sounds strange
Have you replaced the post motor filter? It could be time to do that.
Perhaps your cyclones are clogged as well. You can find steps to disassemble and clean your cyclone, pretty easy actually. Only 6 parts inside there and they only go together one way so you can't screw it up. Search google for dc14 cyclone disassembly and you'll probably find the video. I just did my DC17 and it took about an hour total to take apart, clean and then reassemble. You can also take the opportunity to wash all the parts and disinfect with a mild water bleach solution. That'll help with the smell.
I am betting though that your post motor and premotor filters are the blame for the smell.
I bought my DC 17 from some lady who used it to clean her cat's litter boxes. Cyclones were totally clogged after only 6 months. What do you expect from poop and wet kitty litter. She said it was junk and bought a $1500 Kirby in it's place. She's gonna have some new and interesting smells with that machine sucking up wet kitty litter.
My older Dyson DC14 (the purple one) early model
Have a look at
www.dysonmedic.com which has some very useful info on dismantling and repairing Dysons.
Although this site doesnt actually cover the DC14 yet, the DC14 is very similar to the DC07 so as regards dissassembling the machine, and replacing the clutch, my experience is that the DC07 info will enable you to do the job.
My dyson dc14 makes a
On mine, it was the two little wheels on the outer back portion of the vacuum head. Where the red tabs lock in to hold the brush cover in place.
Dyson dc14 reset button location
Does my dc14 have a brushbar control?..there is nothing I can see that I can do?..it won't hoover my new long pile rug?...please help
I took the roller brush off to clean it,replaced it now it will only spin in the recline position.l put it in the vacuum position and it stops. I have a DC 14 animal.
I'm not sure what you mean by recline and vacuum positions. Normally when the handle is in the upright position to use the tools and hose the brush roll does not turn. When you recline the handle into the floor vacuuming position the brush spins. If you were able to remove the brushroll an reinstall it the brush roll belt is likely very stretched out because otherwise it is very difficult to put the bush roll back in with out using the belt change tool. This can cause the brushroll to spin but stop spinning when when it hits the carpet because he belt is too loose. Belts must be very tight to spin the brush roll in he carpet. There is also another belt that you can't see under the clutch cover. It becomes stretched out also. The belts need to be replace every few years as do any stretch belts. The hard part about changing belts on your model is they are inside the clutch, it's easier to replace the whole clutch. If you have any questions or need any of the parts or belt change tool please email me at
[email protected].
Problems with suction on floor of vac
Often times when people bring a vac in for repairs and say it has no suction at the floor it has good suction but not good agitation. Make sure the belts in the clutch are new (some people are selling used clutches with stretched out belts) and the brush roll is good. If the agitation from the brush roll is not good it will not pick up even light soils like hair and lint.
Dyson blowing top of cyclone air release valve.
It sounds like the same problem I was having. I had loss of suction through he hose then all of the air was coming out through the vent/valve on top of canister. If you are looking at your dyson from the back, look at the bottom. You will see a purple plastic tab on the bottom left. That allows you to remove the plastic u-shaped hose that goes from the hose to the bottom of the dyson. I just removed that and found it was completley blocked. I removed it and the dyson has no loss of suction orair through top valve/vent. I hope this helps. I never post but i'm just excited that I got my dyson working perfectly again.
I had a clog in
Check to make sure the wands and tubes are all put back on properly.
I have a DC14. About
your clutch has failed 29 for new clutch, your local vac shop will charge 49 all in for service and wash and new clutch
When my Dyson is upright
Hello, this is Ava with Think Crucial.
To fix any you vacuum problem, a proper maintenance will do the trick. Most of the time cleaning the filters, checking for blockages and clearing the passageways, and cleaning the brush roll assembly will resolve this. And if after doing maintenance it is still the same, that replacing the parts will most of the time make your vacuum work like brand new.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
While vacuuming, my Dyson starting
To fix any noise issues that your Dyson vacuum gives, a proper maintenance will do the trick. Most of the time cleaning the filters, checking for blockages and clearing the passageways will eliminate the noise.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
