20 Most Recent
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Questions & Answers
Dyson DC17 Loud Noise when using brush bar. I
Hi Ed,I'm sorry to hear you're having difficulty with your DC17. It's worth checking that the new brush bar and belt are fitted correctly, and rotate freely. The video attached may help in making sure it's correctly aligned.It's worth checking that no threads, hair or debris are caught within the machine. The brush bar motor itself isn't designed to be serviced, and we would advise against attempting this in case further damage is caused. I'd encourage you to email our experts directly with our contact details - you can reach them at
[email protected]. Someone will be in touch as soon as possible to take you through some diagnostic checks to confirm what's causing the noise.If you'd prefer to call our customer Helpline, you can reach us on 1-866-693-9766.Best wishes,JackDyson Online Customer Support
www.dyson.com
Changing the HEPA filter on a DC17 Animal
Just took my Dyson in and yes my HEPA needed changing. It's under the right wheel (as you're looking at the machine); you can see it through the "vents" above the wheel. The screw is on the bottom of machine.
You will probably need a Torx (star) 15 screwdriver -- that's what Dyson seems to use everywhere.
Dyson DC 17 Asthma allergy Vacuum
I had a similar issue. I called Dyson. Hey why not, the number is right on the from of the machine. SO IS the beater bar on/off button, right next to the big red on/off switch. It does have a safety off when something jams the bar from rotating so the motor doesn't burn out. I also removed my sock and on restarting the thing, the beater bar would motor was not turning on. I thought the reset would be inside but no, it is right outside in plain view, which I didn't see either. It is a grey button opposite the big red on/off switch. Boy did I feel dumb after that phone call!
My Dyson Animal vacuum smells
hi Donna.
Complete removal of pet hair from the home is a quandary many pet owners face. The Dyson Animal series vacuums use centrifugal force to remove animal hair from carpets, floors, curtains and upholstery. The high-powered vacuum is bagless, allowing you to extract pet hair from surfaces without worrying about running out of vacuum bags. As your Dyson Animal vacuum is exposed to pet hair and dander, a smell can develop. Similar to other small appliances, a vacuum needs periodic cleaning to keep it looking and smelling clean. When you use basic cleaning and deodorizing techniques, you can get the smell out of your Dyson Animal vacuum.
Step 1
Remove the bagless receptacle for pet hair according to the directions provided for your Dyson Animal vacuum. Hold the receptacle upside down inside a trash bag and tap the bottom to remove pet hair and dirt.
Step 2
Mix 1/2 tsp. of dishwashing detergent with 1/2 gallon of warm water in a bucket. Dip a clean cloth into the soap solution and wring it out.
Step 3
Wash the inside and outside of the receptacle with the cloth to remove dirt and dander that cause odor. Rinse the receptacle with a cloth dampened with water. Dry it thoroughly with another cloth.
Step 4
Remove the HEPA filter from your Dyson Animal vacuum. Pick visible clumps of pet hair off the filter and discard them. Flush the filter with cool water to wash out dirt and hair. Rinse the filter until the water runs clean. Gently squeeze the filter and allow it to air-dry for up to 12 hours to ensure it dries completely.
Step 5
Moisten a cloth with undiluted vinegar. Wipe off the exterior of the vacuum with the vinegar. Deodorize the receptacle and interior areas, where the bagless receptacle and filter go, by wiping them with the vinegar-moistened cloth. Dry the vacuum with a clean cloth.
Step 6
Place two drops of vanilla extract on a cotton ball. Drop the cotton ball into the receptacle before securing it to the vacuum to prevent odor from building up. Vanilla extract is an effective natural odor absorber.
hope this helps you out.
Dyson dc17 animal how to fix loud noise.
Replacing the brushroll and belt usually takes care of it unless the motor is bad. Remove the belt tensioner. Only a few models had it and Dyson determined it isn't needed.
I opened my dc17 dyson to clean teh motor. trying
I'm not sure about all the switches used in the vacuum, but I recently took some pictures of the power button assembly. The buttons in the picture below are (from left-to-right): Circuit Breaker, Brush Switch, Power Switch
The next picture shows how the plastic buttons that operate the brush and power switches should go together:
And finally, this is how the power button assembly reattaches:
Dyson dc17
If the brush roll is worn out or not working properly it will not pick up even light debris like hair and lint even if you have great suction. Check the brush roll first.
My dyson animal is hard to push on carpet
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
