SOURCE: WHEN I TURN THE IGNITION SWITCH OFF MY ENGINE KEEPS RUNNING
The ignition lock cylinder has to be what I guess you would call timed, if they get this it wrong then the key will do things like what is happening to you, it is an adjustment that will require they remove and reset the position of the lock cylinder.
BOTTOM LINE, TAKE IT BACK.
SOURCE: 2003 CTS Cadillac - stop running while driving
check your camshaft sensor and try cleaning your maf sensor too
replace the ignition switch
It
can be low fuel pressure issue or clogged fuel pump. Or its engine related
issues,--------------- Check
the help link mentioned below to troubleshoot the problem: ------ Engine stalls when gas is given? http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html ------------- Car stalls when MAF sensor is connected? http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html ------------ Car Engine Stalls While Driving? http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html -------------- Car stalls and throws white smoke from exhaust? http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html ------------- Stalls And Dies At Stop Sign? http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html ------------ GMC Sonoma Stalls and idles low http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html ------------ Nissan Pathfinder stalls and bucks on Acceleration? http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html ----------------- 1992 Chevrolet stalls and shutdown? http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html ------------ Stumbling and stalling at idle after engine rebuild? http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html -------------- 1990 mazda 323 stalls and quit running? http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html ------------- 2000 Toyota
Camry: Idling and Stalling Problem? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html --------- 1995 Toyota
Corolla: Stalls, Sputters and Pops Through Intake Manifold? http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html ---------------- 1999 Toyota Camry: Erratic stalling and high engine RPM at
idle? http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html -------------- Dodge Dakota stalls, stumbles at idle. Has low fuel flow and
runs hot? http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html -------------- 1994 Toyota
4Runner: Stalls and Stops While Driving? http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html --------------- 1997 Toyota Camry: Erratic Idle and Intermittent engine
stalling? http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html ------------- Ford Maverick: No Idle and Stalling issues? http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html ------------- These
details will help. Thanks.
