20 Most Recent Electrolux Guardian Bagged Canister Vacuum Questions & Answers
How do I change the air filter
the top of the vacuum where the tools go comes off,the filter goes underneath..Chris
3/11/2018 6:32:27 PM • Electrolux... • Answered on Mar 11, 2018
No suction; beater bar works. Motor does not
This model has a complicated trouble-shooting procedure that needs to be done by an authorized Aerus Electrolux service tech.
This is often caused by a bad relay board or a Triac. However, problems in wiring or swswiches, including the hose wiring.
I stress that this must be done by an authorized Aerus Electrolux service tech.
http://www.aerushome.com/storelocator/
3/9/2018 5:30:23 AM • Electrolux... • Answered on Mar 09, 2018
The filter case that sits on top of the vacuum
This is a propriatary part. You will need to get a new filter cover for the vac from an AERUS Electrolux dealer or repair shop. The vac can run in this condition and your filter will be fine.
3/9/2018 4:22:36 AM • Electrolux... • Answered on Mar 09, 2018
Bad bag sensor
yes it is very simple to take apart and replace. for screws on the bag door and then it is only 3 wires to pull off of old switch
3/9/2018 3:58:47 AM • Electrolux... • Answered on Mar 09, 2018
I need the manual for the Electrolux vacuum
Owner's manual or service manual?
You should be able to get the owner's manual by contacting the nearest dealership or consultant.
Service manual's are only accessible through software downloaded onto franchise computers, and are unavailable in print.
3/9/2018 12:09:00 AM • Electrolux... • Answered on Mar 09, 2018
Power cord will not retract
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
3/9/2018 12:05:39 AM • Electrolux... • Answered on Mar 09, 2018
I have an Electrolux Guardian Canister vacuum.
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
3/8/2018 6:33:24 PM • Electrolux... • Answered on Mar 08, 2018
My electrolux is over ten years old now and doe not have much suction. Changed the bar still no suction or very little. What gives? Wjymw
I am the Sales Coordinator with Electrolux, and personally it sounds to me like your machine could use a service check. Your local Aerus/ Electrolux office should be able to help you out with that no problem. If you are having trouble reaching them feel free to call my office (570)326-1731 and ask for Liz. I hope this is able to help you out.
3/8/2018 6:08:34 PM • Electrolux... • Answered on Mar 08, 2018
Canister starts, but vacuum does not start
Take the hose unpluged see vaccum is working or not.
IF NOT.
  1. BAG FULL
  2. HOSE CLOGGED
  3. BELT BROKEN/LOOSEN
3/8/2018 5:06:19 PM • Electrolux... • Answered on Mar 08, 2018
2answers
Don't know where to turn on the vacuum of the
Usually these types of vacuums havve a foot operated switch that is part of the body and kind of blends in with the body of the vacuum, they may also have a switch on the handle.
3/8/2018 5:05:04 PM • Electrolux... • Answered on Mar 08, 2018
I need a new base plate for an Electrolux vacuum
This part is not available through any vacuum parts house / vacuum store. You would have to check your yellow pages to see if there is a local Electrolux dealer in your area. You might also try to find Electrolux on line and contact them that way.
3/8/2018 4:05:09 AM • Electrolux... • Answered on Mar 08, 2018
ELECTROLUX C101H JUST SHUT OFF
it does have an internal thermal overload device you need to put the vacuum into the shop they should be able to fix it in a few days
3/8/2018 3:55:37 AM • Electrolux... • Answered on Mar 08, 2018
3answers
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
3/8/2018 3:54:42 AM • Electrolux... • Answered on Mar 08, 2018
Electrolux Lux 5500 model Canister vacuum. Need
The part # is 32749.
3/8/2018 3:46:17 AM • Electrolux... • Answered on Mar 08, 2018
Electrolux canister C104A: Unit shuts itself off
I have a similiar problem, but LED light does not flash. I have determined it is a short in the hose wire. THERE ARE NO REPLACEMENT PARTS FOR THIS MODEL OF ELECTROLUX. I'll never buy another Electrolux product.
3/8/2018 3:26:48 AM • Electrolux... • Answered on Mar 08, 2018
Electrolux Guardian Bagged Canister Vacuum Logo
220 questions posted
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Vacuums
  • Electrolux Vacuums
Most Popular Question
dissasemble electrolux el4101a
  • Vacuums
