Washing Machines Logo
K
KAREN MATTAS Posted on Mar 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY BOSCH LOGICXX8 WHILE WASHING KEEPS COMING UP ITH F37 AND WONT STOP EVEN WHEN IVE UNPLUGED IT PLEASE HELP
Level 3:
  • Bosch Master 6,688 Answers
  • Posted on Mar 02, 2019
Cindy  Wells
Bosch Master
Level 3:
Answers
6688
Questions
0
Helped
3533251
Points
21745
The Bosch Logixx 8 washers indicate an F37 error when the temperature sensor is defective. Sometimes this can happen if the incoming water line gets too cold. If that is the case, pressing the temperature button twice may help. (You should see a snowflake in the top left corner of the LCD screen.) Otherwise try thawing the water pipes.
If the problem isn't cold/frozen water lines, then the temperature sensor is faulty, the wiring between the sensor and the control board could be damaged or the control board has a problem getting the temperature information. Check the sensor and the wiring first. Often there is a sheet inside the washer (near the control board) with the expected resistance across the sensor and other parts. Unplug the washer before testing.
Please add a comment with the model of the washer for a parts diagram or price list. If your washer is under warranty, contact Bosch about the error.
I hope this helps.
5 Related Answers
Anonymous
  • 1489 Answers
  • Posted on May 29, 2009
SOURCE: Washing Machine keeps stopping and says "water tap closed?"
Wonderful!! Would you mind giving me a "problem solved" rating -- there should be icons on the screen to do that.
thanks...
Charlie
Anonymous
  • Posted on Jun 12, 2009
SOURCE: bosch wae24363 washing machine, coming up with f17 error code please help
I had this same message last week. It is to do with the water intake (i.e. the water coming in to the back of the machine). If you have checked that the hose isn't trapped or kinked, unscrewed it and checked the filters at each end for blockages (rinse out if necessary), and you still get the F17 message, it may be because your water pressure is too low, in which case you need to contact your landlord (if you rent) or thames water if the problem is external (especially if there are any works going on near your house). Hope this helps!
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 09, 2009
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: My Bosch washing machine (logixx
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Anonymous
  • 15935 Answers
SOURCE: bosch logixx 8 washing machine showing F37
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
MY WASHING MACHINE JUST RECENTLY STOP WORKING,ITS GIVING ME A F19 FLASHING CODE ?
Please always include make and model.
What does the washing machine Error E19 / F19 mean? These error codes indicate the heating time has been exceeded.
Washing machine error code E19 or F19 - Bosch
https://www.bosch-home.com > ... > Self help/Troubleshoot
About fe
I have a Bosch Logixx 8 front load washing machine. The default code of F61 keeps coming up on the machine. Can you help please?
Switch the machine off and check the power to the socket. If this seems good then check the door switch, check the inlet line, check the free water flow when the power is switched. Also check if there is presence of any moisture within the board, if so use a dryer to carefully heat the boards. If this wont help then the controller unit can be suspected.
1helpful
3helpful
F37 fault code on washine machine
the machine has a defrost function, pressing the temperature button twice will start this and show a snowflake in the top right hand corner Press the temperature button twice, ( A snowflake will appear in the top left corner) this acts as a defrost button. F37 will probably occur more often if your machine is stored in a outhouse. or try thawing out the water pipe.
5helpful
Bosch logixx 8 washing machine showing F37
1helpful
My Bosch washing machine (logixx 8) shows error code F37 and beeps I have the same problem and was wondering whether it was to do with the cold weather as ours is in the outhouse where there is no...
4helpful
43helpful
5answers
My Bosch washing machine shows error code F37 and beeps
My Bosch washing machine shows error code F57 and beeps
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
