For fill cycle check inlet screen filters if ok bad solenoid for short cycling check pump if ok check belt or motor
SOURCE: Washing machine will not drain.
Hi Simon,
I am not that familiar with the Miele brand, but it is possibly a stuck valve. I have had this problem on an AEG and the problem was resolved by cleaning the filter which was totally clogged with fluff and coins left in pockets! I am not sure if yours has a filter. If it does you might look for a rather large screw out filter, usually on the lower front area for easy access. Good luck!
Alf
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
SOURCE: water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only:
A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Door locked light flashes.
After turning off at power point, then restarting unit will commence but light starts flashing again and machine stops
