20 Most Recent LG WM2455 Front Load Washer Questions & Answers
LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
8/19/2018 11:54:29 PM • LG WM2455 Front... • Answered on Aug 19, 2018
3answers
My LG washer wont turn on, if I unplug it from the wall and plug it back in, it will work for one cycle, but then the next time I go to use it, I have to unplug it again to get it to work.
After searching for the answer as to why my LG WM2455H wouldn't start unless I unplugged it and then plugged it again, and trying many "solutions", such as holding the power and start buttons for x amount of seconds, I finally found one that worked. Just before ordering a new control panel, I decided to search one more time for an answer, and found a young man claim that his uncle told him the answer to solving the problem. It's a little weird, and I was very skeptical, as you will be, but it DID WORK to let my washer power on after running cycles of wash. Here it is: Within 12 seconds, push in the POWER button and let go, then open and close the washer door, repeat by pushing in power button again, and let it go, then immediately open and close the washer door again. Do this six times within a 12 second time span. According to the young man on youtube, this procedure RESETS the controls. I would still be a little skeptical, except my machine behaves like it's suppose to now. PLUS, I did nothing that might be attributed to the solution (except think about how I was going to move the heavy washer away from the wall to replace the Control Panel I planned to buy). So, I hope this works for you. It certainly saved me a lot of time and money.
5/16/2018 4:33:51 AM • LG WM2455 Front... • Answered on May 16, 2018
Hi! We bought our WM2455H washer on February
Do a tub clean cycle. Hottest water, no clothes, cup of bleach in washer, fill bleach dispenser with bleach, fill softener with bleach. Run once or twice. The 'grease' is actually residue from liquid detergent and/or softener. So stop using liquid detergent and switch to powdered (no residue believe it or not). Use plain white vinegar in place of softener. The acid eliminates the mildew residue and also helps get detergent residue out of your clothes. Good luck.
1/1/2018 12:47:02 AM • LG WM2455 Front... • Answered on Jan 01, 2018
3answers
How do you remove the top from an LG WM2455 washer?
No... it is not safe to operate with the top loose... Watch the video... Then find you EXACT MACHINE. http://www.appliancepartspros.com/lg-hinge-4774fr3118b-ap4437237.html#autoplay
9/27/2017 3:15:29 PM • LG WM2455 Front... • Answered on Sep 27, 2017
2answers
The code cl keeps coming up and the washer will not shut off
CL is child lock. Press and hold the child lock button(maybe a key icon) for three seconds to unlock
3/27/2015 7:05:00 AM • LG WM2455 Front... • Answered on Mar 27, 2015
I get as code that has a upside down F with an E
most likely it is the motor position sensor also known as a hall sensor. very common issue on older lg washers. easy fix, inexpensive fix--$20. check out appliancepartspros.com or repairclinic.com for excellent videos on how to replace. type in make/model and you will find videos. replace with oem/lg part. do not get oem equivalent part. good luck.
3/17/2015 4:28:47 AM • LG WM2455 Front... • Answered on Mar 17, 2015
My wm2455h turns on by itself and after some time, it turns off. What is causing this>
It seems that the Main Control Board of your washing machine is playing up. The fact that when you unplug the machine from the mains, the main control board resets itself and you are able to start the machine points in this direction.
11/26/2014 8:35:39 AM • LG WM2455 Front... • Answered on Nov 26, 2014
My LG WM2455 has water leaking from lower front near the front access door. I have checked the catch basin and drained the tube but still get leakage after the next load. What could the problem be?
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable. Check the condition of the drain hose that connects the tub to the pump.
10/22/2014 1:43:57 PM • LG WM2455 Front... • Answered on Oct 22, 2014
2answers
LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
3/28/2014 10:24:46 PM • LG WM2455 Front... • Answered on Mar 28, 2014
Prewash hose comes loose
have you cleaned the pipes out there may be a blockage do look at where the pipe pops off from??? and where it goes on ??that may want cleaning out????
2/3/2014 9:47:49 AM • LG WM2455 Front... • Answered on Feb 03, 2014
0answers
0answers
0answers
0answers
2answers
My washer is showing dE
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
4/21/2013 6:07:01 PM • LG WM2455 Front... • Answered on Apr 21, 2013
LG WM2455 Front Load Washer Logo
127 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
lg washer wont turn unplug from wall
  • Washing Machines
