20 Most Recent
Bosch Classixx WFC 2465 Front Load Washer Questions & Answers
Bosch wfr2460 washer not working after replacing
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter? If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
Fabric conditioner section in draw always full
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Bosch conditioner drawer
This problem is caused by the compartment not filling up sufficiently to start the siphon action. First ensure that the drawer is clean, especially the siphon tube then, with the drawer removed, check the top of the compartment. You will find various holes that let in the water, make sure these are clean and not blocked with mould. Clean out with mould remover and wire then run a cycle with no washing or softener/detergent in the machine.
