20 Most Recent LG WM3987HW Front Load Washer / Dryer Questions & Answers
Washer leaks but onlyu during drying cycle
the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
2/6/2017 9:58:45 AM • LG WM3987HW... • Answered on Feb 06, 2017
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is fun job its has to come all apart
7/26/2016 5:17:28 PM • LG WM3987HW... • Answered on Jul 26, 2016
LG washer/dryer combo WM3987HW is leaking from bottom of unit during wash and dry cycles.
Check the valve if there is issue to need to replace
7/19/2016 4:55:07 PM • LG WM3987HW... • Answered on Jul 19, 2016
2answers
My girlfriends LG wm3987hw just lost its power. the outlet is fine. there is absolutely no power getting to the machine. No lights, nothing. Anyone else have or had this problem? Fixable or DOA?
the wm3987hw has an internal fuse located on the "power connection noise filter", It's a transformer or something which cleans up the wall-supplied voltage a bit before it touches the expensive electronics. You might just be able to replace just the fuse, otherwise the whole unit is part#6201EC1006T, about $50. take the top off the unit (two philips screws on the top back) you will find the power noise filter on the top inside right wall of the unit. it's not terribly involved to do this fix yourself. 20minute job tops.
8/3/2015 10:15:28 AM • LG WM3987HW... • Answered on Aug 03, 2015
2answers
I just had the LG
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
7/19/2014 6:34:16 AM • LG WM3987HW... • Answered on Jul 19, 2014
Service manual for lg wm3987HW where can I find
http://www.easyrepairmanuals.us/search-service-manuals/src:wm3987hw/maxrecords:50 Looks like there's a fee for it, but this may be what you're looking for.
6/24/2014 12:33:54 AM • LG WM3987HW... • Answered on Jun 24, 2014
Wm3987hw squeaks
Probably a loose or worn belt.
5/29/2014 9:16:07 AM • LG WM3987HW... • Answered on May 29, 2014
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual. relevant info pasted below: -- Regulate a specific spin speed that generates excessive vibration and noise as follows: 1) Put an unbalance part (rubber) inside of the drum. (this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.) 2) Start the QC test mode (Refer to section 7-2). 7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode" 3) Press Delay Wash button, then ' tst ' is displayed on lcd 4) Press the Spin Speed button repeatedly to select Extra High. 5) Press the Quick Cycle button, the spin speed is displayed. 6) Press the Start/Pause button. 7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration and noise. 8) If there is no vibration and noise, increase the spin speed by pressing Beeper button. 9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50 and 100 rpm). In case of 600 rpm, it can not reduce the spin speed. 10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds). * If you want to return to factory default spin speed setting, repeat above steps except step 9)
3/26/2014 3:56:55 AM • LG WM3987HW... • Answered on Mar 26, 2014
Few months old WM3987HW won't
Hi Rick, I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
12/29/2013 5:02:13 PM • LG WM3987HW... • Answered on Dec 29, 2013
0answers
LG WM3987HW Front Load Washer / Dryer Logo
32 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
girlfriends lg wm3987hw just lost its
  • Washing Machines
