Which model is it?
For Windows OS Factory Reset errors, the easiest way is to reach Windows technical customer service. They provide an instant solution and help for email setup and password related issues.
Read the full solution here -
How to factory reset windows
Restore Windows XP to factory settings
If no tools are available from the PC manufacturer, e.g. recovery disc or recovery partition, use the following tools from Windows XP itself to reset a computer to its factory settings:
Restore with installation CD
Follow these steps:
To continue installing a fresh copy of Windows XP without repairing, press ESC.
If you don't have the "press R" option, you can't perform a Repair Install.
9. Once highlighted, press R
10.Wait for the process to perform Repair Install
11. Windows XP Setup will begin to install the operating system again
12. Continue with the steps of the wizard to setup the system again.
Xp is 100% obsolete now, nobody runs it. and support ended at MS in 2014, you missed that? it is a virus magnet, you are in the 0.2% world wide, using it. the last? love williams post just down load a ISO from where, virus sites,? torrent sites. the tooth fairy? answering for RESET = reload windows fresh. reset really means NOTHING much, or can be everything, 1 bit or 1billionion bits can be reset. the 2 ways are. windows recovery or windows fresh loaded. why use XP now? http://pcdied.com/XP-sux-sg.html
Either youll need a windows xp installation CD or there may be a restoration image on your hard drive you can initialize. If you dont have a XP CD then you can make one by downloading a ISO image of your version of XP (Youll need a cd key to install). XP is old and you should not use it anymore due to security issues.
SOURCE: How to Reset Windows XP Professional SP3 to factory Default Settings
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
SOURCE: HP A620N DESKTOP WINDOWS XP RESET TO FACTORY SETTINGS
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction this may vary depending on your computer and operating system (Note:this will erase all datas on the computer) or you might try Restart your computer during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart You will also need to set the time and date hope it helps
SOURCE: How do I data fatory reset an hp compaq nx9600
Try pressing [F11] repeatedly on Start-up, to access the Factory Recovery Partition.....
However, PLEASE note that you will NOT find Windows 7 drivers for your laptop if it is that old. (confirmed, HP only supports XP on that model.)
IOW....*IF* you could manage to get win7 to install on it, it is HIGHLY likely that parts of it would not work....video, network, cardbus slot, audio.....all of these would need windows 7 drivers to work properly.
you would likely be able to see a monitor image, but not be able to change the resolution much (stuck at 800x600) and the others....would be hit and miss. and if your network adapters (LAN and WLAN) did not work, I'm not sure of what use it would be to you.....
This is one of the pit-falls in Laptop/Notebook ownership. Although some models have lasted through more than one OS, they are a tiny minority.
I suggest you get a recovery CD for your model Compaq laptop from the HP/Compaq WEB site.
You can download the Recovery CD and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
http://www.daossoft.com/knowledge/how-to-reset-hp-password-hp-laptop-password-recovery.html
