20 Most Recent
HEWLETT-PACKARD HP Mini 1103030NR Netbook Questions & Answers
Install printers
What OS are you using? Win 7? Is the Printer and the netbook on the same network? Setup the Printer on the Access Point/wireless device that the Netbook is connected to, make discoverable, turn on wireless, on the Netbook, Start menu, Open Devices and Printers, click on Add a Printer, All a Network, Wireless printer, follow the setup. Take a look at this vid:
http://www.youtube.com/watch?v=ogUtDfaB5ms
Why my web cam is not working
Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver xp
Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: webcam name webcam driver you might have to try a few times to get it right
software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
It might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
hope this helps
No display on screen.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad. Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display. If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Hp 110-3030NR just bought used,
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
http://www.daossoft.com/knowledge/how-to-reset-hp-password-hp-laptop-password-recovery.html
Skype audio people can not hear my chatting
In your sounds icon in the control panel, check to see what the computer thinks you are using for sound recording. For instance, the microphone should be listed if you are using one. If you have a headset, it should be listed instead of a stand-alone microphone. If you are using a mic, it should be plugged into the pink jack on the sound card (or motherboard).
My wireless driver program was
If this just happened just restore it to sometime yesterday or last week etc. If that doesn't work of if you have done a bunch of work you don't want to backup, copy, or loose then just go to the HP website and download the driver again.
When turned on it boots
That line is there to tell you that Windows is completely missing. You will have to reinstall it: for that borrow an USB cd-rom unit and the Windows install disk and use them to reinstall it - use your key, on the label at the bottom.
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
HP A6519FH Black Screen Issue:
I
what computers.?? 1000's of models over 30 years. made
F10 is BIOS screens, so if that works, BIOS. and any screen
then the PC is not booting.
try booting to CD? *(a free linux live cd?) as a test.
if that works
run HDD tests. next
ill stop here, if you can get this far, we go to next step
F11 HDD reload the OS, if PC is 2006 or newer from HP.
