How old? Likely needs a new batterry.
$25-30 Ebay or
https://www.dyson.com/support/journey/replacement-parts.html
SOURCE: dyson blowing top of cyclone air release valve.
It sounds like the same problem I was having. I had loss of suction through he hose then all of the air was coming out through the vent/valve on top of canister. If you are looking at your dyson from the back, look at the bottom. You will see a purple plastic tab on the bottom left. That allows you to remove the plastic u-shaped hose that goes from the hose to the bottom of the dyson. I just removed that and found it was completley blocked. I removed it and the dyson has no loss of suction orair through top valve/vent. I hope this helps. I never post but i'm just excited that I got my dyson working perfectly again.
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
SOURCE: My Dyson DC07 stops working after a few minutes.
Have you tried calling Dyson? I had a problem with my Animal, and their tech department talked me though the fix. Worth trying them first.
SOURCE: Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
SOURCE: hi, i took apart filters to clean in my dyson dc25
Hi its Darran at Dyson.
It may be worth taking the filter in the ball out and putting it back making sure it has clicked back into place securely.
If you need advice on this, please visit our website at www.dyson.com and click on the support section.
Alternatively, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Testimonial: "I went to the dyson website...and figured it out thru pictures. Thank you!"
