SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
SOURCE: My Beaumark Bottom Freezer Refrigerator Doesn't Work
problem is probably that the evaporator is frozen up preventing circulation of air and the fan is jammed with ice.
remove the back panel inside the freezer. melt off the ice with a hairdryer taking care not to heat up any stats mounted on the pipework.
appliance will now work but this is a temporary repair. you must find out the cause of the ice build-up ie why not defrosting.
for starters, check the defrost heater and the thermal cut-out inseries with it.
let me know how you get on and what you find. make sure the fan is free to rotate.
tresilla
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
SOURCE: LG Model LFC23760 (French Doors, bottom freezer) power prob
Unplug fridge.
Open panel on back of fridge (the one at hip height that says Service Panel Only - Do Not Remove, blah blah blah)
See pictures here: http://www.amazon.com/LG-LFC23760SW-French-Refrigerator-White/dp/B00198A5C0/ref=cm_cmu_up_thanks_hdr
Replace fuse with 9A 250V slow-burn fuse. I used a gray fuse harness from Radio Shack so that if the fuse needs to be replaced again I can just pop in a new one without doing the soldering over.
I nuked the original fuse, the end-caps and the wires that went from the end-caps/fuse to the motherboard. I replace those wires with some I scavenged off a fresh thermal fuse (also bought at RS, just needed the wires themselves which seemed to be the same diameter/gauge as the original leads) and ran them from the motherboard to the wire harness.
So far, so good!
Good luck to you.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
