20 Most Recent LG LRSC-26922 Side by Side Refrigerator Questions & Answers
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
LG LRSC-26922... | Answered on Jun 23, 2018
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
LG LRSC-26922... | Answered on Dec 27, 2017
PCB control fault. Don't keep perishables more than 6 hours. If the date on it is "best before" don't worry too much; if it's "use by" keep it refrigerated or use it today, even if you have to cook it and refrigerate it when fridge repaired.
LG LRSC-26922... | Answered on May 04, 2017
I would make sure all the doors are completely closed. If you can't completely close one of your freezer doors, you may have ice built up behind it. Take your freezer bin out and see if you have to defrost.
LG LRSC-26922... | Answered on Apr 18, 2017
I take it your water line is not copper. It may be old and getting fragile. I would replace the line with copper and check the water pressure in your home to make sure it isn't too high. (the maximum water pressure for a residence is 80psi.)
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
LG LRSC-26922... | Answered on Dec 28, 2016
check the water supply to the fridge has it begin shut off or has the water line begin pinched behind the fridge
LG LRSC-26922... | Answered on Feb 19, 2015
open the front of dispenser check spring might be broker or came apart.
LG LRSC-26922... | Answered on Jun 27, 2014
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
LG LRSC-26922... | Answered on Jun 25, 2014
You will need to remove the front display panel to get into the funnel frame.  Look at the bottom of the frame and you will see a little slot to slide a screwdriver in.  With your screwdriver, insert it into the hole and pry gently.  You will hear snaps and cracks as it comes apart.  It may sound like the plastic is breaking but that is normal.  Once you remove the display panel, you will see the frame and just replace it with the new one.
LG LRSC-26922... | Answered on May 24, 2014
Wow, almost a year later but here goes;
I use combinations of buttons to disable/change settings on my LG. To disable the bell press and hold Express Frz then press and hold Filter until the display 'flashes' once, the bell should cease.
LG LRSC-26922... | Answered on Jan 27, 2014
LG LRSC-26922 Side by Side Refrigerator Logo
187 questions posted
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
motor in lg making loud noise
  • Refrigerators
