After replacing the formatter board the old one was in english. how can i change the current one to read in english
1) The display language can be changed by accessing the setting from the printer's control panel.
2) Go to the printer control panel and choose the settings, select date and language, and choose your preferred language and press ok.
3) After pressing it, the language changes automatically in the printer.
For more printer related support visit our website https://goo.gl/g8nmM7.
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
SOURCE: CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
SOURCE: Need to change from chinese > english on HP F4280 DeskJet All-in-one Printer
Well it installed in chinese and I need to change it to english so I can read it, how do I do this? Does it matter
SOURCE: HP 4250 laserjet will not go through the start up sequence.
Well first do what joe said about checking the Plug on the Display, <Here's another solution did you also check the cables( Power Cables going to the format bd ? Sometimes you can bent those pins easily, I have seen it and ok I done it once on HP 4 plus when i first started out as a tech ? Check that ? May I asked What was the reason for replacing the Formatter board in the first Place ? were you getting an error ?
