20 Most Recent HP LaserJet 5200 Printer Questions & Answers
2answers
Hi..,please i want to change
You will find to set the language in this manual:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00575070/c00575070.pdf
There is also the possibility to change the settings via Web Server. You will find in the same manual how to use the Web server.
12/19/2023 1:10:38 PM • HP LaserJet 5200... • Answered on Dec 19, 2023
2answers
How can i solve error code 4900FF HP 5200 ?
This is occur due to few things, first you have to check your document is not corrupt, if it is ok then you need to restart your printer once.
7/26/2021 7:07:17 AM • HP LaserJet 5200... • Answered on Jul 26, 2021
2answers
HP 5200 printer . Coming out only blank paper. Toner is good What is the problem ?
The shutter that covers the laser may not be opening. I have had the arm that opens the shutter break. The printer does not have a way to detect this error so it thinks everything is fine because all the laser operation sensors are inside the laser assembly itself.
2/1/2020 2:13:53 PM • HP LaserJet 5200... • Answered on Feb 01, 2020
49 server error
49.xx.xy error- General firmware error ( like a blue screen in windows) a corrupt print file is usually the cause and can be cleared by disconnecting the printer from the network, then cycle the power , allow the machine to come to ready and ask the pritner for a configuration page( just a test to see if the printer is able to respond- if not then replace formatter/firmware chip) when this has finished printing goto the workstation that sent the last files to the printer and clear ALL print queues form the PC then and only after clearing the print queues can you re-connect the network - failing to clear the print queue will cause the printer to re-try printing the corrupt document which will result in 49.xx.xy error being displayed again.
5/20/2019 8:56:20 AM • HP LaserJet 5200... • Answered on May 20, 2019
Error 49.4c18 hp laserjet 5200
hp 5200 printer error messages 49.4c18
11/24/2018 4:39:10 PM • HP LaserJet 5200... • Answered on Nov 24, 2018
0answers
My HP5200 13.20.00 Paper Jam
Replace the Fuser.
10/2/2017 6:38:30 PM • HP LaserJet 5200... • Answered on Oct 02, 2017
0answers
sounds like your fuser sensor or the fuser is bad
8/2/2017 4:32:40 PM • HP LaserJet 5200... • Answered on Aug 02, 2017
2answers
I have 5200 hp laserjet printer is a problem
A jam has occurred in the registrationassembly area.1. Press the 'down arrow' to see step-by-stepinformation.2. Open the top cover and remove the printcartridge.3. Remove all media inside.4. Lift the metal flap and remove anyremaining media.5. Verify that the media size matches thetray settings and the dial on the tray.6. Reinstall the print cartridge and closethe top cover.7. To exit, press ? .
7/25/2017 11:35:52 AM • HP LaserJet 5200... • Answered on Jul 25, 2017
2answers
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
7/25/2017 11:18:56 AM • HP LaserJet 5200... • Answered on Jul 25, 2017
2answers
Printer prints a faint offset ghost image
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility.Details and specificationsFile name:s.gifHPPDU.exe [1/1, 1.54M]System requirements:s.gifNo additional prerequisitesReleased:s.gif2010-08-13Version:s.gif3.0.0.013Compatibility:s.gifMicrosoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XPFix/Enhancement:s.gifThis version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
12/24/2016 1:51:25 PM • HP LaserJet 5200... • Answered on Dec 24, 2016
49.00ff error in hp laserjet 5200
Does the same thing happen if the printer is disconnected from the network (I'm assuming that you are using an Ethernet connection) before you power-off then power-on again? If it does, then there is a problem with the printer itself. If not, then it may perhaps be invoked by some system sending a 'rogue' job (not necessarily a conventional print job) to the device. Look at HP support site for the latest firmware update to your model. Regards, Mike
4/7/2016 5:30:11 PM • HP LaserJet 5200... • Answered on Apr 07, 2016
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
12/5/2015 12:47:12 PM • HP LaserJet 5200... • Answered on Dec 05, 2015
Good day i'm having a freezing problem with my printer if i send 10-100 prints it processes then prints half the job and then freezes with processing written on the screen please help!
Dear Sinclair The freezing occurs due to two things. 1- when you command print file size is more than the buffer RAM of the printer. ( it will solved choosing page no. selection to print). If there is option to increase the RAM of printer, may be up graded. 2- Fixing temp. when exceeds predetermined temp. it takes a short time may be neglected. Thanks.
3/20/2015 11:03:11 AM • HP LaserJet 5200... • Answered on Mar 20, 2015
145 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
good day having freezing problem printer
  • Office Equipment & Supplies
