20 Most Recent HP LaserJet P3005n Printer Questions & Answers
Check the following link, it will explain the error number 49 you have.
http://www.printertechs.com/tech/error-codes/error-codes-20-49.php
HP LaserJet... | Answered on Oct 17, 2018
This is a common problem with that model. It generally means that there is something going on with the formatter assembly. The easiest thing to try first is to remove any cards from the EIO slots
The next few steps will narrow down if the formatter is bad or the print engine itself.
First remove the right cover by sliding it towards the rear of the printer
Then stick something "non metallic" in the hole indicated to press the engine test button. This will tell you if print engine is working (a good thing!)
If you get a page to print out, that means there is something wrong with the formatter and you should have a service technician replace it.
If you don't see a page, be sure you are pressing it in all the way and if there is still nothing, it's time to have a technician come take a look at it.
HP LaserJet... | Answered on Feb 01, 2018
Do a factory reset then reconfigure device one more time.
HP LaserJet... | Answered on Jan 24, 2018
Did you try to open and close the toner door after you closed the rear bin?
HP LaserJet... | Answered on Dec 28, 2017
The reason it isn't pulling from tray 2 which automatically is automatically the default tray is because the pick up rollers are bad. Replace them and you will be all set.
HP LaserJet... | Answered on Oct 02, 2017
all prints are blank or print 1 page after every print job?
HP LaserJet... | Answered on Dec 06, 2016
try doing upgrades on the printer
HP LaserJet... | Answered on Feb 16, 2015
Go to your menu and select paper handling. From there you can reset the paper settings. If paper will not pull from tray 2 you probably have worn out feed rollers.
HP LaserJet... | Answered on Jan 31, 2015
The DIMM chip is located in the formatter board, that cage where the network cable is attached.
You have a pick up roller that needs replaced. If you pull the tray out, take a flashlight and look up into the printer. You will see a black roller. It probably is covered with white paper dust and slick looking. This needs replaced. That is all that is wrong.
According to the service manual this is a sub cooling fan error. This fan is on the left side of the printer. 25365811-vovdf0wduqj1a05k1fbz2dih-2-1.jpg
HP LaserJet... | Answered on Jan 14, 2015
tIpically streaking on P3005 is related to the toner cartridge. First I would try replacing the cartridge. If that doesn't resolve it the next more likely cause is a fuser.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
HP LaserJet... | Answered on Sep 24, 2014
I had the same problem, the transfer roller rubber was completely slick and would not pick up paper (it would also make a clicking sound).
Replaced it and the problem went away.
HP LaserJet... | Answered on Sep 18, 2014
50.4 is not listed in the service manual but fuser errors are most often caused by bad fuser. Occasionally a power supply or DC controller will fail but seldom is that the case.
HP LaserJet... | Answered on Aug 20, 2014
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font. http://www.fixya.com/support/t6031482-hp_laser
HP LaserJet... | Answered on Aug 04, 2014
worked by power off and back on. However, we had to cancel all pending jobs
HP LaserJet... | Answered on Jul 22, 2014
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
HP LaserJet... | Answered on Jul 13, 2014
HP LaserJet P3005n Printer Logo
351 questions posted
Clive
Clive
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
printer error 59 60
  • Office Equipment & Supplies
