Or the big washer in solenoid is burnt & sticking take apart sand big copper washer & part it touches reassemble .. you may also ask this ? at harleytalking.com they have helped me...
Are you pressing the big button on the front that looks exactly like an on/off switch? because the real on/off button is small and black, and on the side panel by the back.
According to manual, press the Menu button. Then press the right side of the big button with OK in the middle. This will highlight the setup menu (the wrench and hammer icon). Press the down button (lower part of big round button) to highlight date and time. Press up, down, right or left of big button to move cursor and change values. The press OK. Press Menu again to exit.
Follow the instructions on p.12 of the following pdf:
http://www.geberit.com.au/web/appl/au/wcmsau.nsf/files/usr-pdf-Geberit_Outlet%20Valves.pdf/$file/Geberit_Outlet%20Valves.pdf
Basically, push down the 'full-flush' (big) side of the flush button and look at the side of the remaining (small) side of the button. There is a little slot that allows you to pull the small button out. You can then pull out the big side of the button which exposes a screw that allows you to pull the lid off.
Hope that helps.
You can try to calibrate the hoops by having the machine turned off and the largest hoop and smallest hoop ready hold down the start/stop button and the needle theader button and turn the machine on while holding those in, you should get a different screen that say a/d test in the upper left corner, put the largest hoop on the machine being shure the screws are tight and hit the l button on the upper right side the numbers next to the button will change, then put the smallest hoop on and hit the ss button once the thats done turn off the machine and on again and it will start normally and try your designs again if that doesnt work take it to a brother service center/ dealer and tell them to check your x-axis position
