20 Most Recent
Mustek DV526L Camcorder Questions & Answers
I lost my charger for my digital camcorder
If you really can't find the one for your Camcorder, go and look for a Universal charger that comes with all sorts of plugs which one will fit your camcorder. When you get this Universal charger check the voltage on it. Usually the universal charger comes with many settings. Buy one with the settings that correspond to your camcorder. But one word of advice though, you must be careful when you use this kind of charger. Suppose your camera needs 8Volts for power (this is written on the label at the bottom of your camera) you be cautious then use the next lower level if it is say 6Volts. If your Camera powers on with this then keep it that way. the reason for my saying this is that sometimes the Universal Caharger is unreliable so you might get too much voltage from what is written on the Charger. Good Luck.
I CAN'T TAKE ALOT OF PICTURES AND VIDEOS EVEN
You could get a bigger memory card. Otherwise you'll have to find a computer to dump the files on in between recording video/pictures. The other option would be to go into your settings and turn the quality down.
How do I get
Having gone over three months without a response to my query, I assume my suggestion to use a card reader solved the problem.
DRIVERS
You didn't specify what operating system, but here's the driver for Win2000/XP/Vista:
http://www.mustek.com/product_resources/drivers/dv/dv526l/dv526L.zip
It's the only one Mustek has on their site for this camcorder.
My camera sais card locked
take out your card, and look VERY closely at it; there should be a small switch on it. hit this switch and it should be fixed.
How to change the date and time
According to manual, press the Menu button. Then press the right side of the big button with OK in the middle. This will highlight the setup menu (the wrench and hammer icon). Press the down button (lower part of big round button) to highlight date and time. Press up, down, right or left of big button to move cursor and change values. The press OK. Press Menu again to exit.
Does webcam goes with out
not all webcams have a microphone in built.Please check the manual and also if it has then it should have a seperate connection that will go in the microphone plug in of the computer in order for it to pick up any sound.Do ask if you have any more question.Hope this helps.
