Electrical Supplies Logo
J
JIMmy Posted on Oct 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MITSUBISHI MGE 6700 GENERATOR STALLS OUT WHEN AUTO IDLE SWITCHED TO ON. *JUST REPLACED CARB & FUEL LINES. I have a manual trsf swicth on 2nd brk box for gen. Ran with a load w/ no issues.
CJ Rock
Level 3:
  • Electrical S... Master 4,429 Answers
  • Posted on Dec 05, 2019
CJ Rock
Level 3:
Answers
4429
Questions
0
Helped
1645463
Points
15024
Likely a control board issue but could be throttle actuator (stepper motor).
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198585
Points
1063
If you have plan to purchase a new diesel generator set, please visit at www.dieselgeneratortech.com
5 Related Answers
aaron johnson
  • 204 Answers
  • Posted on Apr 21, 2009
SOURCE: my 1991 mitsubishi magna wagon stalls when in reverse, appears to not get enough fuel? Sometimes stalls in idle at times as well. Can't find the fuel filter (if there is one)...help!
i am not positive on the fuel filter location on the forieng cars but thy usually put them in the back by the fuel tank
i hope this helps you in some way.
but yes all cars have fuel filters
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 07, 2009
SOURCE: I have a Honda generator model EM3500X with auto
The control board that senses load (current) is not working.It should drop to low with no output current. (nothing running)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Dec 27, 2010
SOURCE: engine stalled out,would not start,
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
2strokeJim
2strokeJim
  • 577 Answers
  • Posted on May 23, 2012
SOURCE: chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
Anonymous
  • 6468 Answers
  • Posted on Jun 26, 2012
SOURCE: poulan pro honda engine stalls as auto choke lever moves
it sounds to me that there s a jet inside the carb that is still plugged
Mitsubishi generator mge 6700 issues
unless you rebuilt carb -and soaked tank -replaced fuel lines the crud and lacquer reanimate and block proper fuel flow
Mitsubishi MGE 5800 generator won't start. Will run for seconds when I put gas directly in the carburetor. I cleaned the carburetor etc.
If the engine will start when starter fluid is sprayed into the carb, you missed cleaning some small orifice in the carb. Recheck/reclean the carb and you should be OK.
2answers
My onan 4.0 generator will not idle and is back fireing while trying to run it will run fine for ten min then starts trying to die and starts back fireing when I try to keep it running
check for a faulty sump oil switch . check for faulty coil ( magneto on the flywheel) as the time it runs suggests that it is breaking down internally.
Generator stalls out when auto idle switch switched to on position.
It sounds like a blocked jet and or carb issue, may need to service the carb
1helpful
Mitsubishi MGE 6700 generator. Starts and runs fine, but no longer putting out power. What would it cost to repair this issue?
These generators have a GFI outlet on them, and they do fail. I would suggest you check all output circuits and see if you have any output. If so, pull the GFI and see if it is getting power to the outlet. If so, replace the outlet.
When I have it on it stays on high idle speed. When I push the auto idle it will not change the speed to normal. It idles at high speed all time.
If you have anything plugged into the generator, consuming any electric, it will run at high. It must run at high speed to generate 120V. It will only idle if your turn off the load.
Fuel line
At the bottom of your fuel tank there should be a shut off valve and a shunt that has a line coming from it. (The other end is suppose to run through a filter then to the carb) As for the second. Perhaps a reserve tank or aux tank during the switch of fuel sources
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
