20 Most Recent
Onan CUMMINS 4.0 KYFA/6747 - Cummins MicroQuite Generator, 4000 Watt, Gas C.A.R.B. 4.0 KYFA/6747 Questions & Answers
SHOWS CODE 36
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Most likely, rotor slip riings, brushes, control board (if no stator output)
Onan 4000 not charging battery
Some Onan 4KW do not have auxiliary battery charge windings and rectifier. Are you sure you have one? If not you will need and external charger
Onan 12hdkcd error 27 and 13
Rv onan rv runs but now makes a rackett when running was real quiet
Contact www.advanced-power-technologies (Cummins Dealer) with exact model and spec number. Also there are cold weather options, and cold weather models. Many people buy the RS units of the net, only to find they have been stuck with warm weather models, and they don't start. Does it show a code, or a code 45.
Hard starting
Again, what generator model? Onan have thousands. Be more specific please.
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
