Washing Machines Logo
R
Richie Felix Posted on Oct 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MAYTAG MAXIMA WASHER ERROR CODES F06 AND E03 WHAT ARE THESE CODES ?
Eric Sutherland
Level 3:
Master:
  • Master 665 Answers
  • Posted on Oct 06, 2018
Eric Sutherland
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
263311
Points
2023
1 Related Answer
georgemsmith
georgemsmith
  • 13 Answers
  • Posted on Oct 29, 2015
SOURCE: Maytag Maxima front load washer "master reset"?
To start, E01 and F06 means that your main central control board (CCU) and the motor control board (MCU) are not communicating with one another properly. The motor control board is located under the tub mounted to the floor of the washer. The CCU is mounted under the top panel of the washer and is the part with about 100 wires going into it. You'll want to remove the top panel and the lower front panel to check the wire connections and make sure they are all secure. If everything looks good, then you just have to somewhat guess which control board you want to replace first, either the MCU or the CCU. The problem is that there is no way to test and determine which part is faulty so it's just a guessing game. That's what makes this one of the worst errors to get. I generally replace the CCU first as that is the part that shakes around a lot more during spin and it's the first place that the power goes from the power cord if there is any fluctuation in power, so it makes since that this part fails more than the mcu.
There is no Master reset. The only thing you can do is unplug for 1 minute then plug back in.
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
2answers
My friend has a Maytag maxima washer. It has water under the spinner . It won't spin out and reads codes e02 f06?
Found this...check it out...
https://www.justanswer.com/appliance/8xplq-maytag-maxima-front-load-washer-error-codes-f06.html
Part here....
https://www.repairclinic.com/Shop-For-Parts?query=W10374126
or here too and less money.
They both have videos on how to replace it and 800# tech help.
Call them before ordering to confirm this is the fix.
Best to you.
Maytag maxima ecoconserve washer My washer will not operate. The lights come on as if it will I hear a few noises, but water will not enter it and it does not operate. Error Codes are E02 and F06
you have a communication error from the UI (user interface) to the CCU (Central Control UNIT). It could be the wiring or the control itself
My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
1helpful
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
What do Error codes F04 and E03 mean?
The dryer is in need of service if a code beginning with an "F" appears in the display.
Alternating between F# and E#, the dryer control has detected a problem that requires service.
Call for service.
What does Error code F06 mean
Try this:
Possible Causes / Procedure1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Read more: http://forum.appliancepartspros.com/washer-repair/11384-front-load-maytag-what-error-code-f06.html#ixzz33vFGkt1n
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
