SOURCE: thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
SOURCE: location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
SOURCE: location of the thermal fuse on the kenmore gas dryer 80
It is mounted on the rear of the dryer on the blower housing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: On the Kenmore series 90 electric dryer, where is
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
