20 Most Recent Amana ALE331RAW Gas Dryer Questions & Answers
My dryer heats up but
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
1/15/2011 4:14:11 AM • Amana ALE331RAW... • Answered on Jan 15, 2011
How do you adjust a slipping belt for an Amana #
The belt ribs go against the drum. This link shows various configurations BELT CONFIG.
Your dryer tech service manaual: AMANA DRYER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/13/2010 5:58:30 PM • Amana ALE331RAW... • Answered on Oct 13, 2010
Start cycle does not respond
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/30/2010 12:08:12 AM • Amana ALE331RAW... • Answered on Sep 30, 2010
Burnt, scorched smell in the dryer
Remove the bottom front panel(2-3 screws along the very bottom. . Clean inside... Be really careful around the ignitor they are fragile but take care to make sure there is nothing inside the burner tube.
I hope this helps please let me know if you need further assistance.
4/14/2010 4:12:51 AM • Amana ALE331RAW... • Answered on Apr 14, 2010
No heat from dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
1/13/2010 12:39:56 PM • Amana ALE331RAW... • Answered on Jan 13, 2010
The dryer takes alomst two hours to dry a load of
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
12/27/2009 7:30:07 PM • Amana ALE331RAW... • Answered on Dec 27, 2009
Need service manual for Amana Dryer Model No.
Try this website, they may have what you need.
Good luck,
I hope this helps.
http://laundry.manualsonline.com/manuals/device/clothes_dryer.html?
11/15/2009 7:14:30 PM • Amana ALE331RAW... • Answered on Nov 15, 2009
2answers
Blows circuit breaker
sounds as if there is a short in the starting switch but there is a short somewhere in the controls good luck
Dave
9/15/2009 12:31:18 PM • Amana ALE331RAW... • Answered on Sep 15, 2009
My Amana dryer gets clothes stuck between the
Sounds like the drum bearings are worn out. this leaves a gap for the clothers to stick into. You will need to replace them. Check the support rollers also when you have it apart.
9/1/2009 3:22:17 AM • Amana ALE331RAW... • Answered on Sep 01, 2009
Timer goes from 47 minutes to minute in about minuets
replace timer
8/24/2009 1:22:57 AM • Amana ALE331RAW... • Answered on Aug 24, 2009
Amana dryer does not run but i can hear the motor
Sounds like the belt is either broken or slipped off the pulley. Remove the back of the dryer and find the motor. Look to see if the belt is still attached to the pulley. If not, look to see if it has slipped form the pulley and is hanging from the drum, or if it is broken. More than likely, regardless of which it is, you will just need to replace the belt.
6/4/2009 12:21:11 AM • Amana ALE331RAW... • Answered on Jun 04, 2009
Thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
2/24/2009 8:52:17 PM • Amana ALE331RAW... • Answered on Feb 24, 2009
Amana gas dryer
You have to take the front off on that model.. to get at the inside.. heres a diagram that may help ya out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1268&modelDesc=AMANA%20LAUNDRY&modelNumber=ALE331RAW&documentID=M0411885&documentTypeID=PLDM&documentClassCode=PV&titleType=DOOR%2C%20FRONT%2C%20ACCESS%20AND%20TOP%20PANELS&titleID=00002&
12/6/2008 5:59:34 PM • Amana ALE331RAW... • Answered on Dec 06, 2008
Amana electric dryer won't heat up
It can really only be two things. The element or wiring to it has failed or The Thermal fuse has been overheated and cut off power. Both can be checked with a Digital Multimeter. If your Amana dryer is not heating, it likely has either a defective heating element, thermal fuse, high-limit thermostat, or cycling thermostat. If you have a gas dryer, it is likely not heating because of a defective gas valve solenoid. Feb 2, 2022
Amana Dryer Not Heating? Here's What to Do - Fred's Appliance
All question need full make and model to fully assist you. https://www.google.com/search?q=Amana+%28model%29+dryer+parts ..
10/21/2023 11:51:12 PM • Amana Dryers • Answered on Oct 21, 2023
MY AMANA DRYER IS HEATING, BUT THE DRUM IS NOT TURNING AND THE BELT IS NOT BROKEN
see pics and check for bad bearings and or bad motor switch, loose belt or belt not conected to motor tensioner belt replace tensioner belt-undefined-undefined-0.jpg belt tensionerdryer3-undefined-undefined-1.jpg belt tensionerdryer3-undefined-undefined-2.jpg beltswitcht-undefined-undefined-3.jpg bearings dryer old newoldbearing2-undefined-undefined-4.jpg beltswitch-dryer-lint-filter-in-door7-undefined-undefined-5_0.jpg
7/22/2023 10:13:39 AM • Amana Dryers • Answered on Jul 22, 2023
Amana ALE331RAW Gas Dryer Logo
22 questions posted
Top Amana Dryers Experts
Kolbrun...
Virgil Watts
Are you an Amana Dryer Expert? Answer questions, earn points and help others
View Most Popular
Amana Dryers
  • Amana Dryers
Most Popular Question
dryer takes alomst two hours dry load
  • Dryers
