20 Most Recent Amana NDG2330AW Gas Dryer Questions & Answers
manual
NDG2330AW Gas Dryer Manual
Amana DryersUploaded on Oct 24, 2013
Buzz setting
The buzzer is not adjustable on your model.
12/21/2011 7:31:03 AM • Amana NDG2330AW... • Answered on Dec 21, 2011
How do you switch the
You dis-assemble the interior of the dryer and re-route the exhaust vent to the rear.
7/17/2011 8:45:17 PM • Amana NDG2330AW... • Answered on Jul 17, 2011
Dryer runs but does not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
10/6/2010 3:25:48 AM • Amana NDG2330AW... • Answered on Oct 06, 2010
My element turns on and the gas will light ocasionally.
If the igniter is glowing and even sometimes lights the burner, it's not the igniter that's bad. I've created a checklist that most homeowner's can use to trouble shoot dryer lighting problems. Click on my username, scroll down my profile to my tips and tricks for trouble shooting gas dryers.
Hopefully, one of these tips will solve your problem. Good luck.
5/18/2010 2:36:44 AM • Amana NDG2330AW... • Answered on May 18, 2010
Amana dryer runs. Took the vent off. Saw glow. didn't stay on.
Well it could be a problem with the flame detecter. 287476c.jpgWith age the bi-metal tends to take a lot longer to reset so that the ignitor can begin another heat cycle. The ignitor is either gonna be good or badff65907.jpg no in between. The coils that open the gas valve tend to get hot and short out with a little age.4c17c1c.jpg That is a common problem with these good old gas dryers. You need to inspect the blower housing and filter area for air restrictions.a0d89cc.jpg Lets see what else? Oh yeah the control mounted on the blower housing could be bad. It has 4 terminals,3829896.jpg 2 small ones that operate a heater that heats up the bi-metal disc inside to make it shut down faster for knits and permapress stuff. Clever ain't it? Note:These photos are correct in nature to this response but not specific to your model. Now that you have an idea what to look for you need to be sure and order the exactamundo by using your model number amigo. Get parts:
http://www.appliancepartspros.com/partsearch/
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5/8/2010 11:26:39 PM • Amana NDG2330AW... • Answered on May 08, 2010
Dryer does not stop. Does not stay hot during the
Check and make sure your exhaust vent is clean and clear of any blockage.
10/10/2009 6:27:33 PM • Amana NDG2330AW... • Answered on Oct 10, 2009
Dryer leaking
Bubble test! If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7/30/2009 12:05:24 AM • Amana NDG2330AW... • Answered on Jul 30, 2009
Amana electric dryer won't heat up
It can really only be two things. The element or wiring to it has failed or The Thermal fuse has been overheated and cut off power. Both can be checked with a Digital Multimeter. If your Amana dryer is not heating, it likely has either a defective heating element, thermal fuse, high-limit thermostat, or cycling thermostat. If you have a gas dryer, it is likely not heating because of a defective gas valve solenoid. Feb 2, 2022
Amana Dryer Not Heating? Here's What to Do - Fred's Appliance
All question need full make and model to fully assist you. https://www.google.com/search?q=Amana+%28model%29+dryer+parts ..
10/21/2023 11:51:12 PM • Amana Dryers • Answered on Oct 21, 2023
MY AMANA DRYER IS HEATING, BUT THE DRUM IS NOT TURNING AND THE BELT IS NOT BROKEN
see pics and check for bad bearings and or bad motor switch, loose belt or belt not conected to motor tensioner belt replace tensioner belt-undefined-undefined-0.jpg belt tensionerdryer3-undefined-undefined-1.jpg belt tensionerdryer3-undefined-undefined-2.jpg beltswitcht-undefined-undefined-3.jpg bearings dryer old newoldbearing2-undefined-undefined-4.jpg beltswitch-dryer-lint-filter-in-door7-undefined-undefined-5_0.jpg
7/22/2023 10:13:39 AM • Amana Dryers • Answered on Jul 22, 2023
Amana NED7200TW dryer. Which brands/models of pedestals are compatible with it please?
Question edited for clarity.
10" Pedestal for Front Load Washer and Dryer
Amana https://www.amana.com > ... > Laundry Organizers Amana 10" Pedestal for Front Load Washer and Dryer - White (XHP1000XW). ... Raises Your Washer and Dryer to a More Comfortable Height for Loading and ... US$278.00 · ‎In stock More here https://www.google.com/search?q=Amana+NED7200TW+dryer+%22pedestal%22 ..
7/6/2023 4:36:31 PM • Amana Dryers • Answered on Jul 06, 2023
Amana dryer model ngd7200tw smells like gas when it runs and it's not heating up
That is dangerous. Call for service, the law says only registered gas technicians can work on gas appliances. Turn the gas off at the rear. There is enough gas in a dryer leak to blow your windows out on that floor. The igniter or thermocouple is faulty.
7/6/2023 4:14:50 PM • Amana Dryers • Answered on Jul 06, 2023
Amana NED7200TW 27 Inch Electric Dryer. On model number YNED7200TW it is turning on but not running.
Question edited for a lot more clarity. Question moved to maker category. The Belt https://www.google.com/search?q=Amana+YNED7200TW+replacement+belt Videos
4/17/2023 8:09:26 PM • Amana Dryers • Answered on Apr 17, 2023
Amana tandem dryer Model# NED7300WW1 temperature button not working
The buttons and the control panel need to be repaired or retrofitted or be replaced.
3/26/2023 8:28:28 AM • Amana Dryers • Answered on Mar 26, 2023
Amana NFW7200TW Front Load Washer. Is there a trick to changing the baffle out as far as accessing screw?
Question edited for clarity.No, you normally do a full tear down and split the outer drum to get to the screw on the inner drum. You could undo it with grips from inside and use a magnet taped to a coat hanger to collect the screw from between the gap.
2/26/2023 2:02:28 AM • Amana Dryers • Answered on Feb 26, 2023
How old is my Amana dryer with serial number MU4745413? Please and thanks.
1947 according to below :>D More likely 2004 and seventh month or seventh week. How do I tell what year my Amana dryer is? Quick answer: For all Amana serial numbers, the first two numbers are the year it was manufactured. If there is no dash or "-" in the serial number, then the next two numbers represent the month, 01 being January, 02 is February, etc. Oct 20, 2022 lots more here https://www.google.com/search?q=amana+dryer+serial+number+age ..
11/26/2022 5:22:55 PM • Amana Dryers • Answered on Nov 26, 2022
Amana dryer new solenoids new thermistor new heating element new circuit board won't fire gas
It is a gas appliance and can only be worked on by a register gas certified technician.
9/4/2022 9:58:45 PM • Amana Dryers • Answered on Sep 04, 2022
Amana dryer runs for 5 seconds. chimes with TS error code. I replaced thermistor and cleared code. still same issues. Help.
Check your lint screen and vent for restrictions or clogs. Then check the resistance for the thermistor at the control board. You need to confirm that the wiring and replacement thermistor are undamaged. Look for the white connector and test across pin 2 (blue) and pin 6 (red). If the resistance is in range, then the control board is faulty. Replace the control board. I hope this helps. Since you already replaced the thermistor, I assume you know where to find the parts list for your Amana dryer. Cindy Wells
7/31/2022 9:30:18 PM • Amana Dryers • Answered on Jul 31, 2022
My Amana 7200TW Laundry Dryer is turning on but not tumbling - What can I troubleshoot?
Question edited for clarity Amanda / Amana :>) Question moved to sub category. Your belt has broken or come off the pulley. Videos in the link. https://www.google.com/search?q=amana+7200tw+replace+belt+replacement ..
4/24/2022 4:36:02 PM • Amana Dryers • Answered on Apr 24, 2022
Amana NDG2330AW Gas Dryer Logo
7 questions posted
Top Amana Dryers Experts
Kolbrun...
Virgil Watts
Are you an Amana Dryer Expert? Answer questions, earn points and help others
View Most Popular
Amana Dryers
  • Amana Dryers
Most Popular Question
amana dryer runs took vent off saw glow
  • Dryers
