I've checked connections. I've used different speaker wires, RCA jacks, speakers, etc.. I've done everything short of removing the cover and going inside. I've repaired amplifiers with bad fuses, cracked solder and bad input/output jacks. It's a fairly expensive unit that I've never cracked the cage on. I was hoping someone out there might have a little experience with the same problem
Fuses only blow when there is a short circuit. In your case it sound like the main amplifier has been playing up and tripping the circuit. But now something has gone completely, but no longer trips the protection circuit. I would have a look inside and pay close attention to the main power amp board. If there is an IC on it suspect that.
SOURCE: sound problem on Sony TA-343 amplifier
If you're not experienced with troubleshooting and repairing electronics, I strongly suggest professional service. There are internal problems and most likely several components will need replacement.
SOURCE: Technics SU-G90 Amplifier from the
because bad connections, probably in the driver section of the endstage, dc current apears on the output and shuts down the output through the relay.
[email protected]
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
SOURCE: connect powered subwoofer
SOURCE: muffled sound from speakers when connected to laptop via amplifier
You need to buy an analog to digital converter box if you want to get superb sound quality from your computer.
