20 Most Recent Sony SY-ICF-C414 Clock Radio Questions & Answers
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
Sony SY-ICF-C414... | Answered on Jan 04, 2018
In this problem change the cassette player belt it will be OK 100% .I just solve the problem in my set
Sony Audio... | Answered 16 hours ago
Try unplugging speaker wires from unit then power on. If it still says it u have an internal short. If it doesnt hook one speaker up at a time and see if it says it. Might be bad speaker or wiring.
Sony Audio... | Answered on Mar 15, 2019
Is the input volume low only from the Denon drm 700? What happens with any other device?
Sony Audio... | Answered on Mar 14, 2019
Go to check your instruction manual of the L5 Sony and you will find every labelled parts or alternatively Google the product it will be helpful... So you can fix it back.
Sony Audio... | Answered on Mar 08, 2019
This item is discontinued, but your best bet to find one is on ebay.com. There are no new ones currently listed, but several used ones. If you could find a new one, it would be a used one as soon as you turn it on, so the difference may not be meaningful, right?
Sony Audio... | Answered on Mar 07, 2019
https://www.sony.com/electronics/support/articles/00032501
Popping sounds can be caused by a poor connection between the speakers,speaker cables, and amplifier. ... Wires can also become pinched in furniture or damaged in other ways, which can cause them to fray and make popping sounds. Check the cable at the amplifier and speakers and replace it if it is damaged.Jul 7, 2016
Sony Audio... | Answered on Mar 05, 2019
Remove the unit and take a look inside the trays as there may be a CD that is jamming the tray as it may not be lying flat on it. Be care not to jar the unit too much as they are very sensitive and shouldn't be moved without tightening the screw that holds everything from moving during transport. There usually is a tiny hole at the front of the tray that you can push in a straightened paper clip and it will manually open the tray.
Sony Audio... | Answered on Mar 03, 2019
Just as a reminder... we aren't concierge service- a simple google search or manufactures search would have led you to the information you wanted- maybe quicker than waiting here for an answer. Anyway here you go https://www.sony.com/electronics/support/digital-voice-recorders-icd-series/icd-px333
good luck
https://www.6ya.com/mrmmike
Sony Audio... | Answered on Mar 02, 2019
Sony SY-ICF-C414 Clock Radio Logo
2 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
set time
  • Audio Players & Recorders
